Author Topic: WANTED: 1978 PE Swingarm Bearings  (Read 2565 times)
Jethro
« on: August 07, 2011, 10:59:01 am »
As the title states.  I'm restoring a PE250 for racing and in need of swingarm bearings.  I had ordered a set from Canada via ebay and just went to install them and they are the wrong size.  Any help greatly appreciated!
Re: WANTED: 1978 PE Swingarm Bearings
« Reply #1 on: August 08, 2011, 07:06:27 pm »
Look for a part number on the bearing. They should be available from a bearing shop. I know the 80 onwards ones are just a plain IKO needle roller and can be bought from a bearing shop. If that fails you can always order them as a Suzuki Genuine part, but one thing i can tell you is that with the late model PE250 bearings they are cheaper as a aftermarket item than a suzuki one and they are the same identical IKO bearings from IKO Japan.
Jethro
« Reply #2 on: August 08, 2011, 09:52:39 pm »
Unfortunately when I dismantled the bike the bearings were so deteriorated that there wasn't much left of them to find a part number on.
I have found a couple of sites showing microfiche diagrams with part numbers, but there seems to be 2 different part numbers for a 78 model.. So frustrating!
Offline Doc
« Reply #3 on: August 09, 2011, 07:05:42 am »
They should be suzuki p/n 09263-20021 and available from a bearing supplier like BSC. They are what's called a 20X28X25mm drawn cup closed end needle roller bearing. SKF list them.
Jethro
« Reply #4 on: August 09, 2011, 07:45:03 am »
Ahh, ok, I'll give that a try..
The ones I got last time were 09263-22022 which are a different size (they state they are for 78-79 PE).
Thankyou :)
Offline Doc
« Reply #5 on: August 09, 2011, 08:20:13 am »
yeh, for some reason they incorrectly list the 09263-22022 for '78-'79 PE250C/N but infact those bearings suit the RM250C2, RM400C, SP/DR370/400/500/650, LT230 quads and some roadies like the VS750 and 800 Intruders. ;)
Jethro
« Reply #6 on: August 12, 2011, 10:35:45 am »
Thanks for the help Doc.. Have ordered the correct bearings now!
Next problem - I can't find the swingarm thrust washers anywhere!  Are there any other bikes that I could substitute from??
