Author Topic: 80s YZ bits wanted.  (Read 6729 times)
80s YZ bits wanted.
« on: August 08, 2007, 01:04:00 pm »
I'm chasing the following bits:
1. LHS side cover for a YZ250J (K might be the same? L is different). Can be a roughy.
2. RHS side cover for a YZ250K (J and L are bother different). Doesn't have to be perfect, but must be decent.
3. Cylinder head for a YZ125G (56mm bore, air cooled, 5-studs).
4. Spokes and/or hub and/or rim to suit the rear of a YZ250J (I think G~K are all the same apart from rim colour???). Obviously a complete wheel would be fine too.
04000 23847 if you can help.
Offline caps 999
Re: 80s YZ bits wanted.
« Reply #1 on: August 08, 2007, 08:02:16 pm »
the j is different that hub and spokes were only made for 1 year
MUGEN power
Offline ELC hunter
« Reply #2 on: August 08, 2007, 09:04:45 pm »
are 125k sideplates the same 250?
« Reply #3 on: August 10, 2007, 10:20:38 pm »
No, the 125K and 250K plates are different. I can use a good RHS 125K plate if you've got one.
And Caps is right about the 250 rear wheels... G, H, J, K and L all have unique part numbers for spokes, hub and rim!? So I still suspect that any of that era YZ250+ rear wheel will do.
Offline DJRacing
  • YZ125X
« Reply #4 on: August 10, 2007, 11:19:23 pm »
I have a YZ125G head if you wanna swap for a set of YZ125C triples?
« Reply #5 on: August 10, 2007, 11:23:54 pm »
X triples I can do, but not C ones. Well, I've got plenty of C top ones, but no spare lowers.  :-[
