Author Topic: Not strictly VMX but still a problem - JR50  (Read 2974 times)
Offline YZ250H
  • Back in QLD Baby !
« on: July 02, 2011, 09:09:23 pm »
Having a few problems with the young fellas JR50.  Hard to start.  When it does it screams and then dies.  Once it warms up it seems to go OK, something is obviously not right as all my other bikes start first (or second  ::) ) Kick.  Any ideas  :-\
I've got the correct plug in it (etc).
Whadyareckon ?
Offline frostype400
Re: Not strictly VMX but still a problem - JR50
« Reply #1 on: July 02, 2011, 09:19:59 pm »
lack of fuel? split intake rubber.
« Last Edit: July 02, 2011, 09:27:06 pm by frostype400 »
1971 tm400 and PE's
Offline YZ250H
« Reply #2 on: July 02, 2011, 09:45:43 pm »
Hmmmm - I will have a look Frosty.  They are not symptoms I have come across before.
Offline frostype400
« Reply #3 on: July 02, 2011, 09:52:18 pm »
The screaming might be it starving of fuel but then if it runs ok after wards I reckon maybe a split air intake rubber take it off and check because if it is that is just like the throttle being screwed on flat out becuase it can pull the air in.
Had it on my pe400. :)
1971 tm400 and PE's
gettinold
« Reply #4 on: July 03, 2011, 12:54:36 pm »
Its getting to much air ( running on) . Check carby isnt loose etc.( knocked out of rubber etc)
Offline pancho
« Reply #5 on: July 03, 2011, 04:10:58 pm »
 Check for a dirt/gummy slide, sticky till some fuel washes it. An indication is slack in the throttle at first then less when it settles down. pancho.
hillsy_badboy
« Reply #6 on: July 18, 2011, 06:48:05 pm »
check exhaust end tip for hornets nest or carbon build up, the JR's and the little quads have tiny little holes in the exhaust end cap, easily block up and do ur symptoms. Done bucket loads during time in suzuki dealerships, common prob with them.
