Author Topic: Lever ratio RM125N/T  (Read 1797 times)
« on: June 26, 2011, 08:19:19 pm »
I'm setting up some Airshox, does anyone know the ratio or how to work it out? Cheers
Re: Lever ratio RM125N/T
« Reply #1 on: June 27, 2011, 09:39:04 am »
Walter would be the best bloke to ask , but we had to work out a rocker ratio on another bike. Removed the spring, suspended the bike, measured the exposed shock shaft, jacked the wheel up 10(or was it 20)mm and then measured the amount exposed shock shaft. Think it worked out close to 1.5:1
HTH
« Reply #2 on: June 27, 2011, 10:10:24 am »
It will be about 2.2:1 on the N/T model. It's 1.9:1 on the B/C model by comparison.
« Reply #3 on: June 27, 2011, 10:21:40 am »
Cool, thanks guys
