Author Topic: Random bits: KX80 rear guard, TS185 fuel tank, YZ250K gearbox, DT1 rear guard.  (Read 1786 times)
All before they hit Epay...
1. YZ250K bottom end. Crank spins freely, rod seems good (light surface rust in little-end journal though). Rust on crank looks a lot worse than it is.
Clutch basket damaged, some steel plates missing. Hub and cover seem OK.
Thread for front sprocket badly damaged.
Generally "try your luck", with no promises... Really probably on good for gears.
Also have flywheel cover (not pictured).
2. TS185 fuel tank. Looks like turd, but actually seems to be quite a good tank!
Very light surface rust inside, no sign of bog, one small ding.
3. DT1 / RT1 rear mudguard.
Again, looks like crap, is actually pretty good. One small dent where the tail-light mount has pushed into it, and a couple of extra holes for number-plate mounting.
4. KX80 rear guard. Very good condition, with no sign of fading or significant scratches etc. Has two elongated bolt holes and some tyre rubber underneath.
Dunno what model its from, but am guessing late 80s or newer.
Make me an offer, and I'll almost certainly say Yes... They'll go onto Epay soon with a 99c starting bid - I'd rather they get used than thrown away...
In Yass, southern NSW. Am happy to post at buyer's expense.
Nathan. 04000 23847
Round two... All of the above stuff will hit Epay tomorrow night.
5. Lots of old mudguards. Some rubbish, some OK.
Five YZ-D/E/F fronts.
Originally fluro 93-ish CR front.
Sanded 85~87 CR rear.
YZ-J+ rears x2.
Black 94~03ish Kawasaki.
Red, painted blue Stilmotor.
White, painted blue TT500.
Blue IT.
White painted, originally black XT250.
Kawi rears (L to R) KDX200C, KDX200A/B, 88/89 KX125/250 and 88+ KX500.
Cut down RM-T.
6. Assorted DT stuff.
Most of the brake pedals are DT125/175 monoshock.
Oil tanks are DT125/175 twinshock, and DT250 twinshock. Both in VGC.
7. Aftermarket trailbike rack. Labelled XL175.
Don't got thinking that I want real money for this crap - the parts are all free, you'll only have to pay a token amount for the hassle of getting them to you... (and if you come pick them up, then that's zero hassle...  ;D ).
Offline Rhodesy
nathen can i please get the two stroke oil tanks thanks
What I lack in bore n stroke
I make up in rpm
You're a few hours too late for the 125 one, but the 250 one is all yours.
TS tank, YZ bottom end, KX80 guard all now on Epay.
Simo63
Hey Nathan how much for the really nice looking YZ D/E/F front guard?  Is it as good as it looks or is it painted?
