Author Topic: wanted: used suzuki pistons  (Read 3293 times)
Offline suz125
« on: May 30, 2011, 11:20:38 pm »
Hi, I'm after a used pe175 piston for measuring.
as well as/or a ts tc or ds 185 piston
any conditon is ok
Scott
« Last Edit: May 30, 2011, 11:28:26 pm by suz125 »
Re: wanted: used suzuki pistons
« Reply #1 on: May 31, 2011, 12:47:22 am »
The TS piston will go into a PE175 to make it a bigger bore if thats what you are thinking of doing.
Offline suz125
« Reply #2 on: May 31, 2011, 05:39:09 am »
not quite.
looking to put it in a t350 motor and need dimensions to check the timing
Offline Rhodesy
« Reply #3 on: May 31, 2011, 04:07:41 pm »
ive got one for a pe 175 standard with a busted skirt im in the canbera.
What I lack in bore n stroke
I make up in rpm
« Reply #4 on: May 31, 2011, 06:27:33 pm »
Does the T350 have off set transfer cut outs like on th T500? if so i cant really see the TS/PE piston working if there is not metal in the skirt where you need it to be.
Offline suz125
« Reply #5 on: May 31, 2011, 07:48:21 pm »
thats why I need one of each to have a look at  :)
Rhodesy, could you post it cod if it is surplus to your needs
Offline Rhodesy
« Reply #6 on: June 01, 2011, 04:12:51 pm »
ok its no good to me.
I make up in rpm
« Reply #7 on: June 01, 2011, 05:34:06 pm »
A reputaple suzuki person has asked me to pass this on
standard 62mm PE175 pistons can be used as a T350 rebel 'big bore' option but it'll need the addition of a 4mm barrel spacer, all other dimensions are the same including port spacing.
Offline suz125
« Reply #8 on: June 01, 2011, 07:01:10 pm »
excellent, is that from experience or secondhand?
« Reply #9 on: June 01, 2011, 07:44:32 pm »
I dont know, but im sure when he sees this he will let me know and i will pass it on to you.
edit - The info comes from someone with a lot of hands on experience with with the GT/T250/T305/T350 aircooled twins.
« Last Edit: June 01, 2011, 08:26:53 pm by LWC82PE »
