Author Topic: FEUL - premium unleaded v's unleaded  (Read 60025 times)
Re: FEUL - premium unleaded v's unleaded
« Reply #15 on: August 08, 2007, 09:29:56 am »
When it' struggling to get on the pipe does it sound really lazy, or does it sound like it's trying hard but not really succeding?
I know it sounds like a stupid description, but: lazy = too retarded, trying hard = too advanced.
Recommended advance for a YZ125 is 1.2mm BTDC. 3mm is a truck-load more (in terms of degrees of crank rotation/time) when you consider the way the piston moves near TDC.
I'd definitely be experimenting with less advance. You might find that you can lean it off considerably with less advance - more power, less dead plugs, etc...
« Reply #16 on: August 08, 2007, 09:45:32 am »
 ??? I'm supposed to come out with all those sorts of answers Nathan ;D
  ditto what Nathan said.Usually 1-1.4mm for 125's ,2-2.4mm for 250's and 3-3.2mm for 400's is a ballpark static timing figure if none are available.
I hope your setting the timing with a dial indicator not with any marks on the flywheel/stator????
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #17 on: August 08, 2007, 10:11:40 am »
due to the dt external flywheel design, the marks are used just as a guide only, so thats a big yes to the dial indicator.
and yes to- trying hard but not really succeding?
which is too advanced as you say.
step 1 is evolving.
thanks again fella's!
"flat bickie"
« Reply #18 on: August 08, 2007, 02:21:32 pm »
if you use a timing light to do a ig test, how do you tyell the RPM ? i was just going to flash min with the old car timing light but then figured how do i get the RPM number.  Whats the story there ? is it the old burrrrp burrrrrrrrr yep thats about 3900rpm or is there a cleaver-er way kids ?
« Reply #19 on: August 08, 2007, 03:32:41 pm »
Pretty much with a tacho freaky.You want to check the timing marks with the light to compare to the marks you made from the dial indicator.Then tell if you have a static or retarding ignition.Then adjust by that A Jaycar shop will have an inductive automotive tacho about $70 and kart shops have them to :D
« Reply #20 on: August 08, 2007, 05:10:59 pm »
Lozza if i had a dial indicator i wouldnt need to use the lazy ol timing light.
I think ill go for a drive to the kart shop might be easier.  hhey lozza im in NSW next friday you got anything i can pick up ? shocks ? gearset ? saves postage :O)
« Reply #21 on: August 09, 2007, 06:37:16 pm »
Lozza
           I now run a 320 main jet with a 55 primary in the PE 400 with the circlip set at the middle running shell racing fuel timing is STD  ;) depending on the day.
Fatboy.... Tried the V power but had to change the jets, Down to 310 and 45
