Author Topic: Suzuki TM400 Suzuki electrics  (Read 1870 times)
« on: May 23, 2011, 03:54:26 pm »
As I've described in the wanted section, the spark on my TM400 has gone missing in action. I've had little experience with Suzukis so I'm not very up with what parts are interchangable between models. I've got two TM250's and a PE400Z that I can temporarily borrow parts from so before I start dismantling bikes I'd prefer not to, my questions to the Suzuki brains trust are...............
*Will the TM250 stator and fit the TM400 without any major reengineering?
*If so, will the TM400 rotor work with the 250 stator? The reason I ask is that my TM400 rotor has been fitted with a 'Skunk Works' external flywheel weight and would like to keep using it.
*Will the PE coil work with the TM CDI?
*Will the PE stator/rotor fit the TM400 cases?
I'm desperate to get this thing running for CD8 for a bikeless komrade to use.
211kawasaki
Re: Suzuki TM400 Suzuki electrics
« Reply #1 on: May 23, 2011, 05:10:33 pm »
yes yes yes no
Offline frostype400
« Reply #2 on: May 23, 2011, 05:20:51 pm »
Don't butcher the Z Firko if it is a help to you I have my 71 tm400 you could borrow parts from it will be a while before I get a chance to start on it anyway, thanks Michael.
1971 tm400 and PE's
« Reply #3 on: May 24, 2011, 10:45:02 am »
No way Michael....the key words were "temporarily and borrow", anything that comes off the PE or the TM250's will be replaced once the correct parts are sourced. I think Dave's answered my questions anyway.....I'll pull the ignitions off both of the 250's and see what we can sort out.
Where were you at the HBBB Michael? We had a bike for you to cut some laps, plus I wanted to meet ya.
Offline frostype400
« Reply #4 on: May 24, 2011, 06:04:41 pm »
I couldn't make HBBB Firko, I wanted too but I had to play footy I couldn't get there.
I will have to get my tm400 sorted I have just got a seat base and I only need a pipe now to be complete, thanks alot Michael.
1971 tm400 and PE's
