Author Topic: KX 125 bits  (Read 963 times)
KX 125 bits
« on: April 29, 2011, 01:52:43 pm »
Still looking for the following bits :::
the bolt that goes into the crank that secures the rotor
the exhaust flange,
standard air box
rear sprocket
rear brake cable
TM bill why you no answer you PM's ???
TM BILL
Re: KX 125 bits
« Reply #1 on: April 29, 2011, 02:40:07 pm »
Sorry Freaky been busy , The rotor bolt is a standard 8mm bolt with 12mm head about 40mm long  and a spring and flat washer.
Re: KX 125 bits
« Reply #2 on: May 02, 2011, 11:17:29 am »
Bump - anyone have the above used or ideas what else fits
