Author Topic: VMX scrutineering  (Read 15130 times)
Re: VMX scrutineering
« Reply #45 on: May 24, 2011, 05:29:57 pm »
Rumour has it that the  2012 rule book has been completely re written , stripped apart and rebuilt defining every out dated, forgotten or unknow quantity , so you will be able to build your bike for an era class and see what in and whats not......  should make life a hole lot simplier with the grey skies moving away....
Offline pancho
« Reply #46 on: May 24, 2011, 05:39:39 pm »
 I thought that was him firko, so it wheely was eh?
« Reply #47 on: May 24, 2011, 05:55:20 pm »
Here is some old Koni piggybacks i saw the otherday. Never seen them before
« Reply #48 on: May 25, 2011, 11:01:55 am »
Who says you cant use piggy back in pre 75 ???  what do you think thermo shocks are ??  or are you using a differing definition ?  Thermo piggies are standard on all YZ, MX and Dt from 1972'
Yes I was using a differing definition, it’s called Forum shorthand, and I was referring to real shocks, not Thermal Flows (do doubt I just insulted someone then).
I had the same interpretation as Wasp in regards to any reservoir outside of the main shock body being remote.
I thought the rule book actually said something about only Thermal Flow piggybacks being allowed in Pre 75 but can’t see it now, either it’s another rule that’s been changed or I’ve been believing my own dreams again.
Offline micks
« Reply #49 on: May 25, 2011, 02:36:30 pm »
firko it`s un-real that roy gay can get on tv but i wouldn`t say "featuring".from tv star to vice pres at city of penrith mcc the only is up for roy.
Offline rough rider
« Reply #50 on: June 20, 2011, 05:43:08 pm »
hi guys , having trouble getting some fork wiper seals ATM , same as this
http://cgi.ebay.com/ebaymotors/10-Sets-CZ-Ossa-Husqvarna-35mm-Fork-Wipers-Seal-Covers-_W0QQcmdZViewItemQQhashZitem2c5445783eQQitemZ190392399934QQptZMotorcyclesQ5fPartsQ5fAccessories
and its holding up my rebuild getting it back on its wheels , just wondering if i can use fork gators in the pre 75 class ?, not sure if they were around back then :)
090
« Reply #51 on: June 20, 2011, 05:57:28 pm »
Gators have been around forever. Have you tried http://www.vmxunlimited.com/products/CZ-Fork-Dust-Seals.html?
Offline rough rider
« Reply #52 on: June 20, 2011, 06:24:58 pm »
yeah i have had a look there , but says like other places i have got some gear from recently , out of stock
« Reply #53 on: June 20, 2011, 06:28:28 pm »
you can use gators. it not a problem, just not fluro  ;D ;D
« Reply #54 on: June 20, 2011, 06:32:49 pm »
Try Charlie Richardson from CRhighperformance in California.
I got mine from him along with seals,springs & damper rods when I first started reusing my 380.
The pipe I ordered earlier this month took less than a week to arrive
http://www.crhighperformance.com/products.html
Offline rough rider
« Reply #55 on: June 20, 2011, 06:44:41 pm »
thanks but i have contacted charlie also , he to is out of stock and currently changing supplier as he has had trouble getting supply , he is unable to tell me when he will have stock
« Reply #56 on: June 20, 2011, 06:50:45 pm »
Bugger. Have you tried CZstuff in the UK?
Offline rough rider
« Reply #57 on: June 20, 2011, 08:38:02 pm »
they list them , sending them an email to check stock
« Reply #58 on: June 21, 2011, 05:13:12 am »
If you don't have any joy I can dig my original set out & check their condition, they weren't split or cracked from memory
« Reply #59 on: June 22, 2011, 05:14:03 pm »
Did you have any luck with CZ stuff?
I found my old ones & they've gone hard but would probably soften up if you soaked them in brake fluid like is meant to happen with old rubber manifolds.
PM me if you'd like them
