Author Topic: CR125m Kickstat.  (Read 1987 times)
Quicksilver
CR125m Kickstat.
« on: February 05, 2008, 11:53:45 am »
Chasing a kickstart for my CR125m. Tried XL175 it does sort of fit but its not right and only cause damage to the shaft if I use it.
I do have an original I could rebuild if somebody has rebuild kit for it. Need attachment pins, ball and spring. Currently just held together with a bolt. Too bloody dangerous, if I were to ride with it I know its going to swing out and smash my leg..
Offline Stewart Allen
Re: CR125m Kickstat.
« Reply #1 on: February 05, 2008, 07:56:43 pm »
Hi Quicksilver,
                  I had the same problem, the ball, spring & bolt are available ex Honda but not the special nut. Buy 2 bolts, the spring & the ball, cut the threaded section off one of the bolts (this leaves just the shanked section of the bolt & bolt head), drill and tap a hole into the bolt (M8 X 1.25 I think) and presto you have all the bits to make it work. I have assumed the knuckle & leg are OK.
CHEERS STEWART
Doing it to old things is fun
# 74 Heaven
IT490 Will be going one day soon
CR125M
SL175 bitza
IT250D needs work
CR250RE Not going as yet
YZ125F
Quicksilver
« Reply #2 on: February 05, 2008, 08:11:33 pm »
Thanks oldstuff. I will gee up my local Honda dealer tomorrow see what parts they can get. They hate it when I rock up wanting old parts.  ;D ;D ;D ;D
