Author Topic: Watta Ya Reckon Lozza  (Read 18743 times)
Re: Watta Ya Reckon Lozza
« Reply #30 on: March 31, 2011, 12:40:31 pm »
What's this? Looks like something embedded.
Offline huskibul
« Reply #31 on: March 31, 2011, 12:55:55 pm »
    It's not the air jet or part of used on bigger mikuni's ? which could lead to leaner /detonation :-\
« Reply #32 on: March 31, 2011, 01:23:13 pm »
The head shows black divots everywhere(marks were made before combustion), detonation blasts the chamber clear the combuston chamber and piston. Deto also erodes the timing edge of the piston.
DR
« Reply #33 on: March 31, 2011, 02:40:06 pm »
I'll near bet it's pre ignition/detonation and the reason the divots in the top of the piston are black is simply because the engine was being ridden hard whilst detonating. Did it have a horrible rattle under load like terrible gudgeon rattle (pinging) and did you keep on the gas whilst it was making such noise? The fragments are bits and pieces of molten metal from the piston crown and cylinder head. Check the port edges also as these can fragment under such conditions.
« Reply #34 on: March 31, 2011, 03:01:22 pm »
Detonation will give a blistered surface on the piston crown but it simply cannot create the small, sharp edged divots the Turtle's piston has.
« Reply #35 on: March 31, 2011, 03:48:00 pm »
Whatcha reckon we run a book. ;D
1/ bet evident damage is
                  a/ physical, as in a bit broken off and bounced around on top of the piston.
                  b/ pre-ignition/detonation.
2/ Further bets,
if bet for a/ the cause was;
                  a/ little end break up
                  b/ foreign matter
                  c/ big end
                  d/ reed bits
                  e/ carby bits
                  f/ others
if bet for b/ the cause was;
                  a/ ignition timing
                  b/Jetting
                  c/ combination of a/ & b/
or you can bet it was;
                  a/ act of God
                  b/ act of Turtle
                  c/ typical of a female (Kattie in this case :D)
My bet is $10 on Physical and $10 on the little end (and that's the remains of a roller embedded ;))
Turtle is 'house' and gets 10% of all winnings for providing entertainment value  ;D.
« Last Edit: March 31, 2011, 03:57:11 pm by mx250 »
Offline Graeme M
  • Administrator
  • Canberra, Australia
« Reply #36 on: March 31, 2011, 03:54:33 pm »
1a-c
« Reply #37 on: March 31, 2011, 03:58:38 pm »
OK, I'll have another stab at it.........it's farked....beat that!!!!!
« Reply #38 on: March 31, 2011, 04:07:30 pm »
Wanta bet? :)
« Reply #39 on: March 31, 2011, 05:20:37 pm »
Have a look at piston pin C clip is there a piece missing ??     Bet 2 f
Offline ricakk
« Reply #40 on: March 31, 2011, 05:28:50 pm »
I Reckon I may not have to race against the big girl on the weekend .
Offline Snowy 76
« Reply #41 on: March 31, 2011, 05:43:29 pm »
 Turtle`s got other bikes to ride!
Couple of CR`s
Offline GD66
« Reply #42 on: March 31, 2011, 05:49:44 pm »
 1/a/a.... little end bits tapdancing... ;)
Offline ricakk
« Reply #43 on: March 31, 2011, 06:09:21 pm »
I wasn't talking about his bikes Snowy
« Reply #44 on: March 31, 2011, 06:11:18 pm »
Ten bucks on the nose of Davey Crocket.
