Author Topic: Flywheel swapping  (Read 10766 times)
Re: Flywheel swapping
« Reply #15 on: April 08, 2011, 03:48:54 pm »
About to do that, should the lines on the flywheel & stator line up there or at TDC?
090
« Reply #16 on: April 08, 2011, 05:07:25 pm »
firing marks.
« Reply #17 on: April 08, 2011, 05:09:24 pm »
Took the head off & checked to see where the lines met up, close enough to 3.5mm btdc-maybe slightly closer to the first line than the centre. Refitted head & checked for good strong spark, doesn't seem to matter which way I connect the cdi unit to the coil
Still no joy, the occasional kickback & the kickstart looks to be developing a bend
Looks like it's back to points for the last mr vmx round & taupo  :(
Hope the lapped in taper holds up
Ian P
« Reply #18 on: April 09, 2011, 12:49:14 pm »
But where was if firing??
« Reply #19 on: April 09, 2011, 01:42:01 pm »
No idea, don't have a timing light & have been at work all day, at least I managed to make a decent mount for my dti while I was there
Ian P
« Reply #20 on: April 13, 2011, 03:22:44 pm »
Sorted yet??
« Reply #21 on: April 13, 2011, 04:07:43 pm »
Points back in for the time being, will try again after taupo when I have more time
« Reply #22 on: April 13, 2011, 06:35:43 pm »
tony
 how do you set up your points just want to make sure i do it the same as my 400 just dosent go as well as my cr250m 1973
thanks
jim
« Reply #23 on: April 13, 2011, 07:25:33 pm »
Use a dti with the head off, I set the phasing(x mark) at 3.5mm then used the thin paper trick to get the points to open at the same point
The bike isn't a first kick bike when it's cold but thats just because I haven't sorted the pilot jetting out properly yet, think I need to throw a #50 at it. When warm it starts easily
