Author Topic: Roller Starter.  (Read 4666 times)
Roller Starter.
« on: March 14, 2011, 10:09:43 pm »
Does anyone have a grinder or car starter motor powered roller starter they'd like to sell?
Failing that, where do I buy the grinder powered rollers?
Re: Roller Starter.
« Reply #1 on: March 14, 2011, 11:11:37 pm »
Buy one ? Thought you were working to a budget there firko?
Here's a  run down.
9 in angle grinder
4 pillow block bearings
 2 boat rollers V/ concave shaped
Some shaft
a small and large sprockets and drive chain
some RHS steel
A 'normaly open' switch.
Approx cost $120 with a saturday afternoon of cutting/welding and machining
Put all together and you get something like this a 1 man operation
CLICK ON THIS
PM member 'suz125' he might be able to show a pic of his
Re: Roller Starter.
« Reply #2 on: March 15, 2011, 11:42:45 am »
It's not the money so much as the time Lozza ;). I'm building 2.5 bikes before HBBB and haven't got the time to dig up my old boilermaking skills to whip up my own.
I'm actually going halfsies with a mate to soften the financial hit.
Worst case scenario...Can someone loan me a roller for HBBB? Of course the old 'you break, you pay' comes into play without question ;).
Offline curly001
Re: Roller Starter.
« Reply #3 on: March 21, 2011, 02:43:05 pm »
Mark give Bruce Kinnersley In Victoria  a call Lightest direct drive 240 volt rollers going. About $770 start my high comp TT500 easily.
Mobile 0417 551255
Ph 03 52783240
[email protected]
Curly3
Re: Roller Starter.
« Reply #4 on: March 21, 2011, 05:54:11 pm »
If you're interested Mark, I'm planning to build a set of rollers that fit under the rear wheel of the car.
Saves having to find 240v or cart around a battery or even the bulk of a small engine to run it.
I can always make 2.
« Last Edit: March 21, 2011, 06:33:51 pm by SlideRulz »
Re: Roller Starter.
« Reply #5 on: March 21, 2011, 06:20:04 pm »
I'll send you a PM Steve ;). Thanks also to Curly, I'll give Bruce a ring. What does he use to drive them...grinder or car starter motor.......or something else?
Re: Roller Starter.
« Reply #6 on: March 21, 2011, 10:53:00 pm »
still seems a lot of money for some chain and a little motor and some tin............
Offline matcho mick
    • Moto Tumbi
Re: Roller Starter.
« Reply #7 on: March 22, 2011, 12:20:21 pm »
Firko,Bruce uses h/d grinders,buys them in bulk,lot of guys use them in r/racing, car driven rollers are now banned from most tar tracks ,or have designated use areas,(to buggery away from everyone) :P
Offline curly001
Re: Roller Starter.
« Reply #8 on: March 22, 2011, 01:52:46 pm »
Mark, looks like a 9" angle grinder. As for using the car type rollers you need two people who understand each other, three is desirable. A solid & level piece of ground and a vehicle that has a non LSD diff.
Re: Roller Starter.
« Reply #9 on: March 22, 2011, 02:18:16 pm »
Thanks boys....I sort of knew in the back of my head that the car rollers were banned but didn't want to say so until I was sure. I've used both types and have to admit that the electric grinder powered job is way better than the car wheel powered version for both safety and convenience. I used Mick Hockleys griner powered starter to start my misbehaving Maico at Nepean a couple of years ago and was suitably impressed at how well it worked.
The other, probably more important reason I need rollers is that because of my dicky old joints I now find myself unable to kick anything bigger than a Pee Wee 50. I'd like to be able to start my bikes at home, without having to call up a mate every time I need to start one up so methinks the grinder powered version gets the nod.
Curly3
Re: Roller Starter.
« Reply #10 on: March 22, 2011, 04:59:43 pm »
You blokes are party poopers, just when I thought I had a plan, you come along with a sane & reasonable argument and put the kybosh on it.
Where is your spirit of adventure.
Okay plan B, starter motor. ;D
Offline bazza
Re: Roller Starter.
« Reply #11 on: March 22, 2011, 05:12:43 pm »
 Marky i will "turbo" the Klub Kevlar margareeta mixer and we can run a Mk 1 Zepher fan belt to the roller to start the beasts.
Embrace patina
