Marque Remarks
Husqvarna
Will 1972 CR250 piston fit/work in 1973 CR250?
Topic: Will 1972 CR250 piston fit/work in 1973 CR250? (Read 2689 times)
Gippslander
A-Grade
Google "Ancient Greek Sculpture for Kids" 2C more
February 26, 2011, 10:29:59 pm »
The subject line says it -- need a 2nd oversize piston kit for my 1973 CR250 that is kit No 16 10 760-03 size stamped 69.93
can get a 16 10 829-03 NOS on ebay -- that is 69.93 correct size -- but what else is different
Anyone out there know
Gippslander
A-Grade
Re: Will 1972 CR250 piston fit/work in 1973 CR250?
February 28, 2011, 09:30:00 am »
OK -- seems there is a difference -- the little side port in the piston is in a slightly different position -- up a bit higher -- Thanks Michael Hughes of Bendigo Dirt Bikes
Moto
A-Grade
February 28, 2011, 07:29:50 pm »
I had this problem with my 72 Husky,from memory the distance from the pin to the crown of the piston is a different length between the two years.
Give Fernando at husky parts a call or email Vintage Husky in the states to confirm.
Brian Watson
First Penton in OZ
March 01, 2011, 11:32:21 pm »
moto is correct..you cannot use a 72 piston in a 73...and vice versa
Marque Remarks
Husqvarna
