Author Topic: Swingarms.  (Read 12731 times)
Offline vmxken
Re: Swingarms.
« Reply #15 on: February 17, 2011, 07:07:11 am »
I have a copy of the '1974 Dirt Bike Buyer's Guide' in front of me, which covers all the bikes and aftermarket goodies available in 1974.  In the 'Frames & Swingarms' section, there aren't any DG products in that listing.  However, you could buy a square or rectangular section swingarm, in 1974, from Red Line, Cycle Products West, Alex Steel Products and Ocelot.  Those four manufacturers all display square and rectangular swingarms, both stock length and extended, for Honda, Yamaha, Kawasaki, Suzuki, Bultaco, Jawa and Hodaka.  Or, companies such as Cycle Products West, who make rectangular swingarms will "also build a custom swingarm for any bike for $22.95."
It would seem to me that anyone today could legally have a square or rectangular swingarm on any Pre '75 bike.
Re: Swingarms.
« Reply #16 on: February 17, 2011, 07:25:58 am »
The Swingarm I'm building could have been made in 77.
The reason I'm useing an 80's arm is one I found it at the tip so the price is correct. About the only parts I'm really useing from it are the pivot's and the RHS arms themselfs. I cut and shut it so much you could never guess where it started from. I will run it at CD8 and keep the standard one maybe run it at the Nats.
Re: Swingarms.
« Reply #17 on: February 17, 2011, 08:44:29 am »
Someone could have made a 2011 CRF450 back in 1977 too...
Its very easy to gloss over improvements in technology.
Either the swingarm is going to make you faster, or there's no point in having it on a race bike.
Either it matters (and you're giving yourself a performance improvement that wasn't available in the day) or it doesn't (and there's no point in getting you knickers in a knot).
Ken, I'd say that you'd be restricted to making the 2011 "replica" arm from materials that were used back in the day - including the dimensions of the RHS.
Offline Marc.com
Re: Swingarms.
« Reply #18 on: February 17, 2011, 09:39:00 am »
I think it is not that you could have made it in the day, but did someone make it in the day ..... I have a bike with modified 81 cr450 RC replica swing arm, it looks cool but no way it is pre 80 eligible. But hey spray it black when you are finished, time honored way or making modified parts disappear.
Re: Swingarms.
« Reply #19 on: February 17, 2011, 09:43:32 am »
Should that be gloss black or matt black?  ;D
Re: Swingarms.
« Reply #20 on: February 17, 2011, 12:51:59 pm »
Re: Swingarms.
« Reply #21 on: February 17, 2011, 02:09:11 pm »
nice one lieth, shows Dg used profabs rouinds even up till 76 so no way its pre 75
Re: Swingarms.
« Reply #22 on: February 17, 2011, 06:46:59 pm »
I agree, as long as you can prove that the particular design originated prior to Dec 31 1974. I've been on this soapbox so many times it's starting to creak but I maintain that the swingarm is a major component of the bike so therefore must have a period precedent. If DG swingarms didn't appear prior to 1975 then they shouldn't be allowed in pre '75 and Slakewells Kato arm is unfortunately in the same pickle.
Re: Swingarms.
« Reply #23 on: February 17, 2011, 07:18:50 pm »
The Redline box section arms Ken is talking about from '74 were chromoly not alluminium. I have all the old MXA mags from the era and DG didn't start advertising box section alloy arms till the '76 models arrived.
Offline huskibul
Re: Swingarms.
« Reply #24 on: February 17, 2011, 07:22:52 pm »
    I have a DG full page  add in a sept 74' "Dirtbike" for swingarms called the "swinger" for honda, kawa ,suz, 125 and  250  all are round 4130 cro-mo with full gusset  :)
Offline ozktm
Re: Swingarms.
« Reply #25 on: March 02, 2011, 03:54:08 pm »
From a Penton/KTM Forum: Found here : http://www.pentonusa.org/forum/topic.asp?TOPIC_ID=1581&SearchTerms=alloy,swingarm
"Monty, Glenn, metalkfab, Rob
Thanks for your interest and quick replies.
AHRMA Eligibility .... both "DG" and "Crossup" had aluminum swing arms "pre 74" .... I have photos.
Rob ... thanks for the compliment ... we spent 6 months in design and test. Also, please read through the web site pages ... there are options for bearing materials from hard aircraft quality nylon to needle bearings.
As for the shock mount it was designed to allow for custom location. Shock mount location flexibility was one of the "must have" design features for our swingarm products.
Currently we do not have a design to incorporate multiple holes along the swingarm. However is the interest and commitment ($$$$) are there VMXpert is ready.
Again thanks ... I hope this info helps
TBC (to be continued)
Dom
VMXpert PP
Dom
Regards,
Adrian Goold #101
Re: Swingarms.
« Reply #26 on: March 02, 2011, 04:28:41 pm »
The swing arm Im building is for my hot rod 77 so I'm not going to try for pre 74 here, I will keep a original for when and if I ride the nats.
Offline ozktm
Re: Swingarms.
« Reply #27 on: March 07, 2011, 02:57:45 pm »
The '74.5 swingarm is basically the same as the '77 but mounting points for shocks and strengthening webs. You can use the '79 Alloy swingarm, just mounts in, but your shock positions will have to move, same motor and frame dims, so fits.
Adrian
Regards,
Adrian Goold #101
Re: Swingarms.
« Reply #28 on: March 07, 2011, 06:47:02 pm »
Adrian
I looked at the 79 and I have seen one fitted to a 77 but there straight without Banana bend so they increase wheel travel allot and then change the whole geometry. I love the way the 77 ride and handle so I don't want to muck with that much.
