Author Topic: 1981 CR 125 Ignition timing  (Read 7028 times)
Offline Husabergpete
« on: February 05, 2011, 02:22:27 pm »
Gents,
The workshop manual I have for the CR 125 says to Turng the Crankshaft counter clockwise from TDC a distance of `C'.
The motor is a 2040.
Trouble is the manual doesn't say what that amount is.  Can anyone help?
I have an original owners manual for a CR 125 (yellow tank) that looks about a 76 or 77 model.
That book said the Ignition Advance before TDC is 1.43mm - 17 degrees. Not sure if would be the same.
Pete
Offline PEZBerq
  • Brisbane
Re: 1981 CR 125 Ignition timing
« Reply #1 on: February 05, 2011, 05:01:12 pm »
Yes Pete it'll be the same for your bike.  My 82 spec sheet says 1.43mm for 125's  so you will be fine.
« Reply #2 on: February 07, 2011, 05:55:02 pm »
Thanks very much for that.
Ya gotta love Husky for keeping stuff the same for us.
Pete
Offline Barronvmx
« Reply #3 on: February 09, 2011, 09:38:42 pm »
Make sure you are dead on with the timing because it could run backwards. I was sitting on the start line in Canberra some years back and when I dropped the clutch on my 83 125 the bike went backwards off the start line into the pits. Funny site to see but I didn't know what the hell had happened. When it was restarted I let the clutch out slowly and moved forward thankfully and was last in the race by then. I fixed the timing and it has never happened again in 6 years touch wood but they are close to TDC so beware.
Huskies
CR250 1972, CR400 1972, SC125 1973, CR250 1975GP, WR250 1979/80, XC125 1983, TX510 1983, XC125 1984 project, CR250 1984 project
Honda's
SL100 1971, XL100 1974, Hondasaki 210, XL185 1981 project
Jawa's
1959 250 project, 1969 175 trail boss project.
Sachs 1969 125
« Reply #4 on: February 10, 2011, 06:28:33 am »
Thanks for that race start tip. Sounds like it pays to ride the bike to the start line and keep it runnin'.
I will get a bit of help with the timing now.
Pete
Offline PEZBerq
  • Brisbane
« Reply #5 on: February 10, 2011, 08:24:44 am »
FWIW I like to check the timing using a timing light to make sure the markings on the ignition are actually accurate and ignition fires at correct time. Mark the flywheel and the cases with a white marker pen when mechanically at 1.43mm BTDC. Then check the timing with the timing light. I do it using a el cheapo light that plugs direct between spark plug lead and spark plug. I can check it by kicking it over with plug removed from engine and earthed against the head. Couldn't get an inductive pick up light to work on my Motoplat at kick over speed.  Haven't tried an induction pickup light with the engine running so they might be fine in a situation where the bike actually runs. Cheers
Harro
« Reply #6 on: February 17, 2011, 09:39:16 pm »
Barron Von Shickleburger,
If my memory stands true you always went backwards on the start line at Canberra also are u going to Connondale to celebrate the year of the Husky and if so I want to scab a ride on your silver bullet
Regards,
Harro
Offline Barronvmx
« Reply #7 on: February 18, 2011, 10:04:22 pm »
Husky Harro
Long time no hear
I have sold the silver beast and now have a TX 510 1983 which is an Ex Tony McMahon ex Paul nelson bike I think. Much easier to ride and better for the riding we do up here which is mainly natural terrain.
And yes you can have a ride but its your shout after, JD of course. Your drinking partner should be coming along also aka Brendan my son so it should be a good weekend. Have you sold all your bikes.
Huskies
Honda's
Jawa's
Sachs 1969 125
