Author Topic: im on the hunt for a 1980 PE 400 crank web clutch side, and also the main shaft  (Read 3261 times)
Mate on the hunt for a 1980 PE 400 crank web - clutch side, and also the main shaft (sprocket run's on)
TM BILL
PM sent  :)
thanks Billy.
Leith , have a good look at that stuff the crank ends more rooted than this one and the other.............
Offline frostype400
Yeah I hate how the crank ends flattern out I have one that has done that.
1971 tm400 and PE's
Yeah i didnt bother looking closely. They can be repaired by any decent machinst in your area though. Its gonna be hard to find a seller of one though unless frosty wants to part with one ;D
typical Pe 400 problem ....broken key way  at a guess.
whats the fix ? cheaper option or HF
Offline frostype400
I may be able to part with one I have 3 bottom ends I have been working on. ::)
1971 tm400 and PE's
freaky, pretty common  on these to have the primary drive nut come loose and break the key way .
Offline frostype400
Haven't seen that before Stu but you know how they flare out on the end like some one has hit the end of the thread with a hammer and mashed it up on the fly wheel side that is a pain.
1971 tm400 and PE's
or better still weld the forker on  :o
frosty, I would have about  6 cranks that have had the hammer treatment on mag side or rooted key ways  ::)
Offline frostype400
You would have loved seeing that when you took the case off.
To think that we get mad when people weld a gear lever on, my cr250 has one foot lever fixed welded because who needs folding levers. ???
1971 tm400 and PE's
Basically you could machine a whole new web and shaft, or machine off/press out the shaft from the web (not sure how its fixed) and then machine up a new shaft with taper, keyway, threads etc and fit it to the old web. Bingo fixed. These days you can almost reproduce or fix anything.
« Last Edit: January 31, 2011, 08:47:00 pm by LWC82PE »
