Author Topic: RM500 Oversize Pistons???  (Read 15845 times)
ranchak
« on: January 21, 2011, 01:08:59 pm »
I was thinking about coming out with a 1.00mm oversize piston for the RM500. Is there any interest? Would you rather have a .75mm piston? Is there anything else that you guys are looking for? Thanks, Ron
www.anchakandsons.com
suzuki43
Re: RM500 Oversize Pistons???
« Reply #1 on: January 21, 2011, 01:56:30 pm »
Hi Ron,speaking as the current owner of two RM500's, in my opinion both sizes (0.75mm and 1.00mm)would be of benefit, given the last Suzuki Oversize is 0.50mm.
Conrods for this model are amongst the hardest to find part I have seen as well.
« Reply #2 on: January 21, 2011, 02:24:00 pm »
From experience, a lot of people leave re-bores too late for a .25mm increase in bore size or they get a score from some grit which doesnt clean up with .25mm so in that case you have to go to the next .50mm size, so i reckon its probably more worthwhile to go std-.50-1.00-1.50-2.00
ranchak
« Reply #3 on: January 21, 2011, 02:39:44 pm »
This is what I was thinking, but I'm not the guy buying them (actually I am)
ranchak
« Reply #4 on: January 21, 2011, 02:40:52 pm »
I have been looking for a suitable replacement, but I haven't found anything yet that will work. I had a rod that I was going to modify and then I find out it's discontinued!
Offline maxi81
« Reply #5 on: January 21, 2011, 04:08:33 pm »
What a bout a replacement rod for a RM 400T
ranchak
« Reply #6 on: January 21, 2011, 04:10:58 pm »
I've been trying to come up with replacement rods for the RM370, RM400, RM465 and RM500. I haven't found anything that will work or that can be modified.
« Reply #7 on: January 21, 2011, 07:48:19 pm »
Are LT500 rods any good? Have you contacted BB importers? http://www.bbimporters.com.au I have got their con rod dimensions for everything they have got.
« Last Edit: January 21, 2011, 07:56:58 pm by LWC82PE »
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #8 on: January 21, 2011, 08:19:51 pm »
so stick it somewhere that people can view it  ;D
« Reply #9 on: January 21, 2011, 09:32:55 pm »
Sorry i cant do that. I would if i could.
Offline maxi81
« Reply #10 on: January 21, 2011, 10:17:17 pm »
Someone has suggested that a KTM 360/380 con rod has similar dimensions to a RM 400T rod. Any truth to this??
« Reply #11 on: January 21, 2011, 10:26:51 pm »
Yeah that was Lozza that said that so im pretty sure he has given correct info there. He would have the same rod dimension charts as i do, probably more also.
ranchak
« Reply #12 on: January 22, 2011, 05:38:28 am »
I think the KTM/Maico rod is .5mm longer. I did a ton of research on this about a year ago and I could not find anything that would work , either OEM or aftermarket, that wouldn't require a spacer between the cylinder and the crankcases.
Offline k2000x
« Reply #13 on: January 22, 2011, 08:31:29 am »
dont know why people want to keep rod charts a secret mate..heres a couple i found www.italkit.com www.rectificados-bellavista.com and www.jokersracing.com they dont have every make and model listed but could be a help even some of the jet ski rods on jokersracing...if all fails prox give them a call they faxed me a list of rods close to what i need with measurements
« Reply #14 on: January 22, 2011, 09:04:35 am »
KTM 360/380 rod is the dimensions I posted the 0,5mm will not make any difference, just use a thick base gasket.
