Author Topic: KYB part # ID  (Read 2876 times)
monaro308
KYB part # ID
« on: January 15, 2011, 03:57:50 pm »
Hi all,i want to id a KYB that came on my PE400.
Its 455mm eye to eye with remote resi and part # is 45014-1109
The # doesn't come up on my Suzook program....could it be a Kawa shock?
cheers....mario
Offline brent j
Re: KYB part # ID
« Reply #1 on: January 15, 2011, 06:32:40 pm »
Check the number carefully. I think the second part of the number should have 5 digits.
That's based on the Suzuki shocks I have around here.
Brent
monaro308
Re: KYB part # ID
« Reply #2 on: January 15, 2011, 07:13:08 pm »
Brent, i checked that,4 digits for sure.
Resi body is narrower than a suzi and the shock body has a plastic sleave between the spring.Spring is progressive wound.
Just curious what its off.
« Last Edit: January 15, 2011, 07:16:21 pm by monaro308 »
Re: KYB part # ID
« Reply #3 on: January 15, 2011, 07:23:33 pm »
A close up pic would help. Also have you measured the length off the bike? They could be KLX or KX, if they have narrow reservoirs, i cant see them being anything else. KLX are 460mm and your probably 5mm off if you measured them on the bike. Yeah just looking again at them, i would say they are KLX250 which are WAY too long for a PE.
« Last Edit: January 15, 2011, 07:25:54 pm by LWC82PE »
TM BILL
Re: KYB part # ID
« Reply #4 on: January 15, 2011, 07:27:09 pm »
Yep KLX  :)
Offline brent j
Re: KYB part # ID
« Reply #5 on: January 15, 2011, 08:39:23 pm »
I should have paid more attention to the length ::)
They are the same shocks I cut up to use on my XT.
monaro308
Re: KYB part # ID
« Reply #6 on: January 15, 2011, 09:09:10 pm »
Yeah measured off the bike Leith,give or take a couple of mm ;D
I figured kawa going by the spring and narrow resi.
It was on there (1)holding up the bike,just a junk shocker really and wanted to confirm the #
Debating on what to do with some junk in the shed and sick of tripping over stuff or moving things just getting to the mower.
Might be time to find new homes.
cheers..mario
