Author Topic: Pe400 Spark Problems  (Read 24243 times)
Re: Pe400 Spark Problems
« Reply #45 on: January 25, 2011, 09:13:14 pm »
As a matter of interest, is the flywheel a PE replacement ???
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #46 on: January 25, 2011, 09:20:14 pm »
it appears to be a complete replacement. Stator and flywheel are NOT original items.
« Reply #47 on: January 25, 2011, 09:28:37 pm »
USB interface cable for programming(there is also a handheld programmer) is about $60
WTF! a USB cable for $60? What on earth is it made from? platinum coated with gold?
 ;D No but I'm sure it could be arranged. PC programming came after the hand held programmer. The cost is in adapting the USB to the 10 pin connector common to all the cdi's, the 10 pin connector had been used from the beginning , the cost was higher to incorporate the small end of the usb into the cdi.
« Reply #48 on: January 25, 2011, 09:45:26 pm »
Yes the flywheel is brand new. You cant use it with stock PE stator though. it only goes with the kit and includes, the coil/cdi, regulator, stator and what ever else is in the photo. The regulator is unecessarily big but does fit under the tank, but you could use your own much smaller one. It might be worth while to double check the taper with them due to this comment from the guy in Canada who has one
It makes spark from a low kicking rpm but it runs on fixed timing, again I can't compare but the 400 seems to run well with it.
It also has enough amps to have a 60w headlight, 23 stop, 20 flashers, running all at once at about 2000 rpm.
The only problem I have had was that I received mine with a flywheel that had a bigger cone than my crankshaft, at first I tought it was a difference in crank taper from 250 ( for wich the system was sold) and the 400 so had a taper sleeve machined to adapt.
I later learned through this forum that it not so and that all 250 and 400 should have the same taper, so mine must have been a mistake at the factory but still I would double check if I were to order one.
Going by what the manufacturers say their ignition is to far superior than the stock suzuki one. Ive put 3 on bikes before and the owners had never had any complaints.
« Last Edit: January 25, 2011, 09:51:29 pm by LWC82PE »
Offline Mike52
  • 81 KTM 125 LC
« Reply #49 on: January 27, 2011, 11:46:01 am »
circa €250 euro by the looks of it.
http://www.powerdynamo.biz/deu/systems/lists/suzuki.php
there is a guy in NSW listed as having PowerDynamo stuff.
http://www.powerdynamo.biz/eng/partner.htm
Oh man that guy in NSW is THE Paul Rooney , husqvarna extrodinare.
rohan
« Reply #50 on: February 18, 2011, 02:26:54 pm »
Its confirmed, faulty CDI. Just put a brand new one on and BIG FAT BLUE SPARK :)
« Reply #51 on: February 18, 2011, 05:51:47 pm »
Do the brand new CDI look the same as how they used to make them or are they in a wizz bang plastic container now?
rohan
« Reply #52 on: February 18, 2011, 09:47:09 pm »
Same as the old ones!
Offline frostype400
« Reply #53 on: February 18, 2011, 10:19:16 pm »
I have to get one. :)
1971 tm400 and PE's
