Author Topic: Front drum brake useless!  (Read 9174 times)
Offline mudguard
« on: January 11, 2011, 10:12:11 pm »
Hi,
How can I get the front brake on my 1976 YZ250 to stop the bike within the distance of a footy field?  ???   I have fitted a new set of  Yamaha brake shoes and a new brake cable, but no matter how much brake I grab, the bike just rolls to a stop. Is this just the way vmx bikes are or can you get the front brake to perform well?
Re: Front drum brake useless!
« Reply #1 on: January 11, 2011, 10:27:41 pm »
That's how they are.. you have to drag both feet then pitch it sideways
« Reply #2 on: January 11, 2011, 10:37:52 pm »
If it makes you feel better, they're the best SLS MX bike drum brake out there...
Clean, not overly polished drum?
Good bearings? (Yes, they matter)
Brake lever with the right ratio?
Decent quality cable?
Is the lever coming back to the bars, or is it firm but useless?
Offline mudguard
« Reply #3 on: January 11, 2011, 10:50:27 pm »
Hey Nathan,
The lever is firm, not going all the way to the bars. It is a cheap lever though. Wouldn't have thought lever types could make much difference? I got some info a while ago that I can take my wheel and brake plate somewhere and they can get the entire surface of the brake shoe to bond to the drum. Don't know who does this though!
« Reply #4 on: January 11, 2011, 11:05:28 pm »
There's lots of different levers out there, and they do make a difference.
The XR Hondah lever will give a bit more mechanical advantage & is easy to get. The genuine Yamaha cables won't fit though, unless you file out the part of the lever blade where the cable passes through - a tedious prick of a job.
Most of the dramas with shit drum brakes that are fixed by matching the shoes to the drum, relate to shit quality components - Yamaha brakes are supposed to work well because they don't have any shit quality components in them...
Try roughing up the brake drum surface with some sand paper and the Honder lever and see how it goes.
« Reply #5 on: January 12, 2011, 08:49:13 am »
Use an inside Caliper ( like and inside ruler) to make sure the drum is round.If it not it need machining.
Try a Yamaha AG 200 front brake cable and lever (or XR 200 lever )
Match the new shoes to the hub by clouring in with texter or white board maker the shoes to find the high spots.
Offline mudguard
« Reply #6 on: January 12, 2011, 08:56:05 am »
Thanks guys,
Plenty of info here to work with. Should get a much better result.   :)
« Reply #7 on: January 12, 2011, 09:35:57 am »
Forgot to add cheap levers and perchs flex at the prech and reduce braking.
Offline Mike52
  • 81 KTM 125 LC
« Reply #8 on: January 12, 2011, 09:38:04 am »
Guys working on Husky,s in Amerika are glueing sandpaper inside the brakedrum and giving the wheel a spin to match the shoes to the drum.
Also fixing the paper to the shoes and giving the drum a bit of a rub.
Never tried it but it sounds good.
Mike :)
Offline Frank M
« Reply #9 on: January 12, 2011, 11:17:56 am »
missing some important points. This is not my language, so have mercy and fun  ;)
- first check the drum. Should not be konical or not round (if so it needs machining)
- check wheel bearings and seals (no oil- or greasedust on the shoes/drum)
- cam in plate must be in good technical order and easy to turn (no worn out bearing)
- quality cable on its way up to the lever guided as straight as possible
- rough the drum with rough sandpaper (P40-80) and wipe out the rusty ring
- rough the shoes also with P80 on the complete function-surface
- install the wheel, pull the brakelever strong and hold it while tighten the front axle! (really important to center the plate in the drum)
- lever on the plate should be in a 90° angle to the cable when brake is pulled
- go an ride a few minutes with using the brake softly
- back in the shed after removing the wheel you will see glossy parts on the brakeshoes
- remove these glossy parts with a fine rasp and ride again (always tighten frontaxle with lever pulled!)
- work is done, if the surface of the shoes wears over 2/3 (glossy parts growing)
- cutting off the lining 10-20mm on the camside of the frontshoe increases the braking effect on single leading brakes
« Last Edit: January 12, 2011, 11:25:54 am by Frank M »
Offline bazza
« Reply #10 on: January 12, 2011, 02:39:07 pm »
frank M has it spot on - works for me,took while on Xl hub but got there
Embrace patina
Offline mudguard
« Reply #11 on: January 12, 2011, 09:50:02 pm »
Hey Frank M.
I will use your advice, step by step, and report on the outcome.  :)
Wayne.
Offline PE MAN
« Reply #12 on: January 13, 2011, 02:02:40 pm »
drums are funny. i found that the drums on the front of my PE are useless when i had it going before restoration. havnt had the chance yet to try an resolve this problem but the front drums on a old xl 250 i had worked great. they really grabbed. have got the front drum of the PE in the shed an it has plenty of life left in the shoes. so i scuffed the shoes with a wire brush. i havnt done anything to the drum will probably just give it a sand paper when i get it back, an adjust it. see what happens when i play around with it.
1980 SUZUKI RM50
1980 SUZUKI PE400
Offline yamaico
« Reply #13 on: January 20, 2011, 01:39:53 pm »
Quote: "install the wheel, pull the brakelever strong and hold it while tighten the front axle! (really important to center the plate in the drum)"
This is really important however I always get the front end off the ground, give the wheel a good spin in the forward direction, jam the brake on quickly and, while still holding the brake on, tighten the axle and pinch bolts. This will generally turn a spongy ineffective brake into a firm effective brake.
« Reply #14 on: January 20, 2011, 05:48:52 pm »
Good one Pete....You put me onto that little tip a while ago and I now do it on all of the bikes and have no brake problems, even the so-called shithouse Maico brakes work great. The difference some of these tips made to my Maico conical front brake was phenomenal. Using the heaviest grade cable and routing the brake the most kink free direct route also add to the efficiency.
Frank M and others have presented some good tips.....
