Author Topic: fuel taps for methanol  (Read 5735 times)
Offline tony c
« on: January 09, 2011, 04:33:33 pm »
dose any one no where to get long lasting fuel taps for metho at a good price I need 4 so the cheaper the better.
Re: fuel taps for methanol
« Reply #1 on: January 09, 2011, 04:36:10 pm »
Speedway shop or a place that specializes in stuff for drag bikes? Dont know if such a thing exists. Do you know the seal material it has to be to be methanol resistant?
Offline tony c
« Reply #2 on: January 09, 2011, 04:41:04 pm »
I no that the speedway type is probly the go but when you need 4 I am sure I could buy them from a tap supplier if I new what seal types is requierd
« Reply #3 on: January 09, 2011, 05:19:11 pm »
My first suggestion is something with Viton seals as that resists normal fuel but im not sure they handle methanol. Are the normal aftermarket Tri/Nor/BSA taps OK? i know they are a lot better than the original english taps.
« Last Edit: January 09, 2011, 05:48:46 pm by LWC82PE »
Offline tony c
« Reply #4 on: January 09, 2011, 05:41:37 pm »
Yeah we have tried the taps you see on ebay even they are no good for avgas the hole blocks up after a short time you have to heat up a drill bit or something to open the hole up, the million dollar ? is what seal type is methanol resistant anyone?.
« Reply #5 on: January 10, 2011, 06:38:49 am »
tony
i use taps from blackwoods an enginering supplyer
try there web site if no luck i can copy the pages from there cat/ and post them to you
jim
Offline tony c
« Reply #6 on: January 10, 2011, 09:30:27 am »
Thats what I wanted to hear thanks Jim
Offline pancho
« Reply #7 on: January 10, 2011, 10:09:06 am »
The ones on my slider are simple ball valves, the ones sold for air lines etc.
  They have a chrome hexagon shaped body, with a red plastic lever on/off.
  So far after about 5 years they are still fine, with no leaks or probs.
  I got them from Scotts Auto One in Penrith. They are available also at any Auto paint shop supplier.
cheers, pancho.
Offline tony c
« Reply #8 on: January 11, 2011, 09:47:29 pm »
Pancho were are they a good price the brass type from blackwoods look ok and are about $18
« Reply #9 on: January 11, 2011, 11:18:06 pm »
i bought some taps recently from one of them Hydrolic airhose fitting and agricultural places, big company name, just cant think of it off the top of me head, but the fittings are like gas fitting but metal , aslo try the plastic ones for model aircrafts/ lawn mower machines with the red tap, about $2.50 and i have had the same one on for 2 years ( bought 3 at the time incase they melted- so far havent needed to)
« Reply #10 on: January 12, 2011, 06:29:05 am »
tony
when using methanol need big holes for it to flow through dont skimp on bore size get bigest inside dia you can get.used lawn mower tap petrol only not enought volume for my cr250
jim
Offline tony c
« Reply #11 on: January 12, 2011, 09:36:47 pm »
Yes good point the standard bsa taps flow about 400mls/min each which is good when you have 2 taps the carby only flows about 400mls/min so you have a bit up your sleeve, but yes the 1/4 inch steel or brass types are even better with a hard type of seal with full flow and not a rubber type seal like the beeza ones
