Author Topic: Yamaha Zedder Help  (Read 2311 times)
Offline AdamN
Yamaha Zedder Help
« on: January 05, 2011, 08:26:24 am »
Was hopeing that someone with the Zedder program can look up a part number please?
Part # is 3R4-16380-01-00 Push Lever
It states it will fit the YZ465G, but I'm wondering if it will fit the YZ/IT465H/J as well. I know some have a breather hose attached, but is that the only difference? I'm sure the L-H case and clutch etc. is the same between the YZ and IT's of that time. I looked up the bearing and seal and it cross references with the other models so the shaft diameter must be the same. Anyone know of any differences, or why it wouldn't work in an IT465H?
Cheers Adam
'82 PE175Z, '92 YZ125D1, '93 WR500ZE, '13 KTM350EXC-F, '16 Husky TE300
Re: Yamaha Zedder Help
« Reply #1 on: January 05, 2011, 08:50:28 am »
Part # = 3R4-16380-01-00
Part Description = PUSH LEVER ASSEMBLY
Model Count = 2
YZ250G 1980 250 YZ250 Competition Motocross
YZ465G 1980 465 YZ465 Competition Motocross
Different model parts may fit as they will come up with a new part No if they only change the colour.
You will need a Yamaha specific Guru to answer your question
Offline AdamN
« Reply #2 on: January 05, 2011, 09:20:53 am »
Thanks for that GMC, that's what Boats.net said as well. I'm pretty sure it will work, but would just like some confirmaation before I buy. Hopfully a Yamaha parts guru will be along shortly with the words i'd like to hear :D.
Cheers Adam
