Author Topic: Anyone seen these before  (Read 2769 times)
« on: January 01, 2011, 12:44:43 pm »
Was looking around for options to tighten up the fit of the bearings on a cz hub & found this. Any opinions
http://www.mcmaster.com/#tolerance-rings/=ae3io7
Re: Anyone seen these before
« Reply #1 on: January 01, 2011, 01:20:02 pm »
Unsure what you posted , try google speedy sleeve and see if that's what you need?
« Reply #2 on: January 01, 2011, 01:44:38 pm »
Its basically a serrated shim sized to specific bearings, you bore the housing oversize- for a 6204 the size is 48.86-48.97mm then slide it into position by overlapping the ends.
From what I can see it would work behind a circlip quite well, fitting the bearing appears to press the highpoints flat locking things up. Thats probably the best way I can think to explain it
« Reply #3 on: January 01, 2011, 01:56:05 pm »
Ok sounds alot like a speedy sleeve which you can buy at any bearing shop should work fine.
Offline pancho
« Reply #4 on: January 01, 2011, 04:01:06 pm »
Thats what I was going to suggest Slakewell. cheers pancho
« Reply #5 on: January 01, 2011, 04:50:15 pm »
I thought speedy sleeves were only for shafts
« Reply #6 on: January 01, 2011, 08:05:19 pm »
Shafts are normally built up and re machined , Inside of housings you would bore it and fit a sleeve , You can sleeve a shaft thou.
