Author Topic: RM400 1mm Oversize Piston Kits  (Read 4176 times)
ranchak
« on: December 03, 2010, 03:06:21 am »
I now have 1mm Oversize piston and ring kits available. The piston is a high quality cast single ring piston. Kits come with piston, ring, wrist pin and circlips. See them at:
www.anchakandsons.com
Thanks for your support!
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: RM400 1mm Oversize Piston Kits
« Reply #1 on: December 03, 2010, 07:11:55 am »
great to hear, Ron !
DR
« Reply #2 on: December 03, 2010, 07:20:23 am »
Ron. I'll be a customer for one of those kits in the not too distant future, was checking out your stuff last night and it all looks great ;)
Just a question, do you have spare rings to suit these 1mm kits? Aaaaand, is it at all possible to have some repro 0.50 rings made?
This is a major stumbling block with the RM400's. You can buy the 0.50 pistons by the dozen but not the ring :(  Unless you buy the whole kit they are simply unobtainium which has left oodles of 0.50 pistons with no rings to suit. Cheers
ranchak
« Reply #3 on: December 03, 2010, 08:33:48 am »
I will be having the spare 1mm rings available ny themselves. I occasionally have .050 ring sets available, I looked into having rings made and the quantity was too high. I may eventually have a .050 piston made and then rings will be available. Any other suggestions?
burty400
« Reply #4 on: December 03, 2010, 09:35:47 am »
Ron thats great news with the 1mm oversize piston.
How about making a  .75 mm oversize piston kit?
DR
« Reply #5 on: December 03, 2010, 01:24:18 pm »
Cheers, any chance I could put in a pre order for an 0.50 ring if/when some more do appear? 1mm overbore would be okay but my bore is good hence why I'm hunting just the ring ;)
« Reply #6 on: December 03, 2010, 05:22:39 pm »
Ron ... do they require shims  @  piston pin.
ranchak
« Reply #7 on: December 04, 2010, 07:06:22 am »
No shims required!!!!! Let me look and see if I have a set of .050 rings, I might have sold the last ones, but you never know....  I can look into having .75mm pistons made, but there has to be a need. If I can get about four or five confirmed buyers I will have them made. Any takers????
burty400
« Reply #8 on: December 04, 2010, 09:42:03 am »
Ron you can put me down for 2 piston kits at .75mm plus 2 spare rings.
ranchak
« Reply #9 on: December 04, 2010, 11:43:25 am »
I will do that, now only three more to go and you guys can have .75mm piston kits. I also have reproduction centercase, clutch cover and head gaskets.
« Reply #10 on: December 04, 2010, 02:01:25 pm »
count me in for a .75 plus a spare set of rings
Offline Mutch
« Reply #11 on: December 05, 2010, 06:09:16 am »
Yes and the same with me Ron
ranchak
« Reply #12 on: December 06, 2010, 02:31:18 am »
Thanks guys, let me get a lead time on the .75mm pistons and maybe I'll do an introductory buy.
