Author Topic: NOW and THEN you have a win.  (Read 25125 times)
Offline Mike52
  • 81 KTM 125 LC
« on: November 30, 2010, 07:54:23 pm »
1985 WR 400 Complete . [ Not running , ignition problems ] :) :) :)
Offline frostype400
Re: NOW and THEN you have a win.
« Reply #1 on: November 30, 2010, 08:03:57 pm »
Cool have you got any photos of the bike. :)
1971 tm400 and PE's
Offline Mike52
  • 81 KTM 125 LC
« Reply #2 on: November 30, 2010, 08:07:18 pm »
Pick it up next week Frosty, photo then.
Mike
Still have to start on that PE too.
Which one to do???????????
« Last Edit: November 30, 2010, 08:09:30 pm by Mike52 »
Offline frostype400
« Reply #3 on: November 30, 2010, 08:27:52 pm »
I being a PE man would still start on the husky first. ;)
1971 tm400 and PE's
EBT
« Reply #4 on: December 01, 2010, 12:28:37 am »
That is a good find.
Offline Mike52
  • 81 KTM 125 LC
« Reply #5 on: December 01, 2010, 12:10:59 pm »
Almost finished my 86 240 WR , gave her the first kick in the guts today and it started on the second kick [ Oh JOY of JOYS ]
That,s with a COMPLETE DT175 ignition fitted , flywheel - stator and cdi. Have tried the $18 [ Ebay ] chineese CDI and coil and they work too.
Happy , Happy.
Now to finish scrubbing the brown stuff off the Fuel Tank. :)
And try to figure out the rest of the wiring.
Oh and fit some real fork seals from the US and NOT the new leaky ones that I got from Ebay. [ Watch those ones , they look like real ones but aren,t ] :o
Offline Brian Watson
  • First Penton in OZ
« Reply #6 on: December 02, 2010, 06:19:43 pm »
Mike..can you detail the Yammie ignition you used..what year etc..also I have a chinese ignition..can you give some detail about how you fitted etc..even maybe some pics..??
Offline Tossa
« Reply #7 on: December 02, 2010, 06:31:26 pm »
I would be interested in the fit as well
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Offline huskibul
« Reply #8 on: December 02, 2010, 06:37:15 pm »
    Me three :)
Offline Mike52
  • 81 KTM 125 LC
« Reply #9 on: December 03, 2010, 09:27:16 am »
Will post pikkys over weekend.
Big job if you have to pay someone .       Ok if you have a small lathe and some sort of idea.
Was first put onto this by HuskyAU on this forum. He has used a later PE setup [ later ones are ideal size and weight ] but finding a flywheel is a real pain.  I searched the world with no luck. Found one stator which I later sold to FROSTY.
Later PE ones are bigger. Early Pe flywheel is too small I rekon. Could use it but motor would be a bit revvy . Chineeze flywheel is OK but the CDI trigger has nowhere to go without cutting the crankcase. Would have liked to use it because you can get the lot for $55.
So I tried a 85 Dt one, works good although it fires on BDC as well. [The way its built ] No probs with that tho.
I had to take the centre out of the flywheel and make a new one with the right taper. Also machined both the backing plates to fit each other. [ pain getting the clearances right ] Pe would have been better. Dt flywheel is a little bit heavy too.
There are 3 different tapers on Huskys so the DT might fit one of them but not the 86,s. :'(
Bought a CDI to suit the DT and also got a Chineeze one and made a kit one to try [ All work OK ] I Am using Chinese CDI and coil on this one. but later Husky[ 98 ] coil works too. [ Has an external CDI so is just a plain coil ]
All works no probs.
One small thing  . The Dt is 6 volts. ::) Bummer
« Reply #10 on: December 03, 2010, 11:56:05 am »
Mike..I'm really curious as to which Chinese ignition you used and it's suitability to suit a 2 stroke. I've got a couple of these ignitions, one earmarked for my Ducati 250 and I'd like to experiment with the other on a 2 stroke, possibly one of my DT1/RT1 engines.
Offline Tossa
« Reply #11 on: December 03, 2010, 12:05:36 pm »
I was wondering whether they would work on my 81, KTM 390
« Reply #12 on: December 03, 2010, 04:16:11 pm »
Um, it might just be me, but it seems like an awful lot of work & mucking around when you can just get your SEM or Motoplat repaired.
Offline Mike52
  • 81 KTM 125 LC
« Reply #13 on: December 03, 2010, 04:50:09 pm »
Yep Bigk you have a point there.
BUT
I have a rewound SEM here [ dud ]
I have just bought a Wr 400 with a DUD ignition.
Mate has a 84 Wr 240 [ on 3rd motoplat now ]
Another mate has a 250 Wr [ ignition DUD]
I had a Montessa King Scorpion [ Dud motoplat ]
Yep a lot of trouble to go to BUT I have never heard of a DT doing it,s ignition and if they do it is sooooo easy [ and cheap ] to fix. :)
Cheers Mike
« Reply #14 on: December 03, 2010, 06:49:42 pm »
Yep...and I even sent a Motoplat away to Geelong...when it came back it was only working when going in the wrong direction ..anticlockwise... :(......now run PVL...but a bit exe.....so any cheaper alternative would be nice...and to tell you the truth ..I am not all that fussed about the quality of the spark on our PVL's..even with an earth wire fitted between the stator and the coil...
