Author Topic: powder coat removal  (Read 6226 times)
Offline paul
powder coat removal
« on: November 23, 2010, 03:09:41 pm »
what is the best way to remove powder coat
paint strip tank
sand blast
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: powder coat removal
« Reply #1 on: November 23, 2010, 03:29:38 pm »
heat, burn, scrap, blast, beer... :)
"flat bickie"
« Reply #2 on: November 23, 2010, 05:37:52 pm »
Depends what is powdercoated.....either sandblast or chemical clean.
Offline paul
« Reply #3 on: November 23, 2010, 06:09:47 pm »
itsa frame . but it was recently powdercoater but i dont like the colour
« Reply #4 on: November 23, 2010, 06:17:47 pm »
Sandblast it, the powdercoater should be able to redo it.
Offline paul
« Reply #5 on: November 23, 2010, 07:03:37 pm »
im told that sand blasting wont get it off
Offline ricakk
« Reply #6 on: November 23, 2010, 07:15:39 pm »
Blast with Garnet will take a while but should take it off .
090
« Reply #7 on: November 23, 2010, 07:26:30 pm »
Sand blasting works but is slow as its hard to get off. I re did my cz frame that was powdercoated.
« Reply #8 on: November 23, 2010, 07:54:09 pm »
A good operater will get it off.
Offline sverige
  • Sunshine Coast
« Reply #9 on: November 24, 2010, 12:06:55 am »
A friend of mine has a sand blasting and power coating business and told me the best way to get power coat off is to burn it off. Not with the oxy, but send it to a specialised power coat removal business to burn it off. As far as i know there is only one doing power coat burns for the whole of  SE Qld.
Offline Mike52
  • 81 KTM 125 LC
« Reply #10 on: November 24, 2010, 07:03:20 am »
You could always bump it , with a spanner and such.
Worked for me when assembling my newly painted frame. :o
I have just stripped the paint of a monoshock spring with paint stripper.
Have been told ,on this forum that it,s powder coat.
Sorta worked, sorta. ::)
« Reply #11 on: November 24, 2010, 09:11:36 am »
I get a company called Colorex to remove powdercoating, new or old it does it easily & cheaply. It's a non caustic chemical bath. There may be a franchise near you.
Offline paul
« Reply #12 on: November 24, 2010, 09:33:37 am »
is there a chance that this procedure will get in side the frame and cause damage from the inside out over a period of time
« Reply #13 on: November 24, 2010, 11:14:45 am »
Nope, it water soluable and the guys give it a good was before handing them back. No different from washing the frame out with a pressure washer.
« Reply #14 on: November 24, 2010, 11:31:36 am »
IF its only just been pwdersoated why cant they lay a new colour over the top ??? get it re powdercoated an new shade of Black.
