Author Topic: Identify engine with engine number  (Read 3403 times)
Offline Christo
« on: November 14, 2010, 02:22:24 am »
Hi all,
I supposedly have a '74 KX450 engine with the engine number K5E-90175.
I was looking thru the kawasaki section in this forum and spied that it should start with K2E?
So what engine do I really have then? Its still in its crate. Looked on google and the closest I found
was a document saying KX400? 1976/7?
Offline Christo
Re: Identify engine with engine number
« Reply #1 on: November 14, 2010, 02:36:53 am »
Just found this,
Kawasaki KX400A 1975.
# 400 cc
# 2-Stroke, 1 Cylinder
# Piston Valve
# 5-Speed Return Shift
# Maximum Horsepower:
# 42 HP @7,000 rpm
# Spark Plug: NGK B9EV
# Tire Size
# Front: 3.00-21 4PR
# Rear: 4.60-18 4PR
# Color
# Fuel Tank: Lime Green, Candy Lime
# Front Fender: White or Black
# Engine No.: K5E903001-
« Reply #2 on: November 14, 2010, 10:18:55 am »
You no it's a sign of mental illness if you answer your own posts!!! ;D
Offline Trent Farlow
« Reply #3 on: November 18, 2010, 09:34:31 am »
Hi Christo  - I checked up and the KX450 engine number goes from K5E900001     you are correct that the first 1975 KX400 engine number goes from K5E903001   - indicates they must have made anywhere up to 3000 KX450's   - the F12MX which was the 1973 forebearer to the KX450 engine number started with just 90001.  Cheers Trent
Offline bazza
« Reply #4 on: November 18, 2010, 01:14:27 pm »
F12.  have not heard from trent for a while,
Embrace patina
« Reply #5 on: November 18, 2010, 02:59:30 pm »
It's not the real Trent Bazza, note the missing e on Farlowe.....PJ Read will be pissed when he find out there's yet another Farlowe imposter in town.
