Author Topic: DT 175 piston into IT 175G  (Read 1817 times)
Offline vmxrider
« on: November 12, 2010, 12:43:57 pm »
Anyone got a DT175E/F/G piston they could measure.
Looking at options for an IT175g.
IT dimensions,
Distance from top of pin hole to edge of crown = 22mm
Crown height approx 5mm
Distance from bottom of pin hole to bottom of skirt = 25mm
Re: DT 175 piston into IT 175G
« Reply #1 on: November 12, 2010, 01:50:08 pm »
DT175 2N4 and 2A7 are the same except IT is 0.5mm longer HTH
Offline vmxrider
« Reply #2 on: November 12, 2010, 02:17:39 pm »
Thanks Lozza, Hmmm, so am I right is assuming DT piston would work even with different skirt length as the reed valve controls intake timing? (assuming windows in piston are the same)
« Reply #3 on: November 12, 2010, 06:05:06 pm »
Christ NO, the sky will fall, sun won't rise in the morning, bushfire, famine, floods etc etc will wreck the vmx world. ;D I'm assuming you have the IT piston to compare with :D
