Marque Remarks
Suzuki
RM 400 T rear springs
Topic: RM 400 T rear springs (Read 3024 times)
maxvmx
November 09, 2010, 03:43:44 pm »
Hi, would anyone know what the free length of the pre load rear springs are on a RM 400 T?
suzuki27
Re: RM 400 T rear springs
November 09, 2010, 04:58:02 pm »
I get 78mm for the small/lighter springs and 212mm for the long spring. This is free length of the standard springs I have.
LWC82PE
Superstar
November 09, 2010, 08:35:58 pm »
Ive got a set comming so will measure for you when they get here, plus i have springs off one shock i already have here and will check those too. incase you were not aware, there was option spring rates availble for the RM too.
LWC82PE
Superstar
November 10, 2010, 09:45:53 pm »
What i ment was that i have some RM KYB shocks comming.
Ohlins springs will fit 36mm ID bodied KYB's. if you know what rate/ length you want i will look it up on the Ohlins chart. Just send me an email.
If your after 78-79 used RM KYB springs i might be able to do a deal with you. I know i have a 79 RM125 set for sure.
Marque Remarks
Suzuki
