Author Topic: stuck swing arm bolt  (Read 2325 times)
« on: November 08, 2010, 02:00:22 pm »
Hi gents I have a stuck swing arm bolt on a 250 mx yamaha twin shocker ,swing arm is bent about ten mm higher on one side ,I would like to save the arm if possable thanks in advance Iainyz
Re: stuck swing arm bolt
« Reply #1 on: November 08, 2010, 02:04:24 pm »
« Reply #2 on: November 08, 2010, 02:15:08 pm »
thanks vmx247 I was after a quick way but after reading that link I think an oxy hack saw will be the best way then look in my scrap pile for a dt swing arm iainyz
« Reply #3 on: November 08, 2010, 03:42:51 pm »
problem solved, a bloke at work had a electric hack saw that fitted between the frame and swingarm
