Author Topic: Its official, im an ag bike owner!  (Read 19520 times)
Offline NR555
Re: Its official, im an ag bike owner!
« Reply #15 on: April 01, 2008, 05:49:08 pm »
CZs are definitely 'different' to ride.  Ours is converted to wet clutch and it seems to work well.  You don't need to touch the clutch that much during races.  I hardly ever do.
Ours isn't a CZ frame, so I can't comment on handling, but I hear they are pretty good.
The long throw gearchange is the hardest thing to adjust to.  My tip?  Don't ride your modern bike back to back with your CZ.  Also, if the motor is on song, it really helps the gearchanges to slot in properly.  If it's dying off too much between gears, I find I hits neutrals more often.
They have the best drum brakes out there, much larger front drum than a Maico, for example.
Ian P
« Reply #16 on: April 01, 2008, 09:00:54 pm »
I've made the move too!!!
Another member for the clan!
090
« Reply #17 on: April 01, 2008, 09:19:20 pm »
Nice one Ian.
No one tell Magoo or im off the team for sure! ;D
Offline d veda
« Reply #18 on: April 03, 2008, 04:30:28 am »
nice pikey did you swap the rm125s for her? whats her history. are the ribs up for it yet.
what are you doing with all the yellow paint now .
Ian P
« Reply #19 on: April 03, 2008, 05:36:11 am »
Yeah the RMS is gone. :(
Ribs are fine! Have still got the TM so will finish out the season on that.
It was one of Russell Burlings. Just need to make a few changes (Plastics, Carb, Pipe?) and give it a good check over before letting loose!! 8)
Offline DJRacing
  • YZ125X
« Reply #20 on: April 03, 2008, 04:05:39 pm »
So it will be the big challenge next year against your brother then Pikey??  ;)  ;D
Ian P
« Reply #21 on: April 03, 2008, 04:08:44 pm »
Some things never change in life!!! ;)
Mark Austin
« Reply #22 on: April 05, 2008, 03:26:30 pm »
Nice one Brad - and, well at least the frame is red, that should appease Mr Magoo...
Mark
