Author Topic: evo class exhausts  (Read 5610 times)
Offline gdr
evo class exhausts
« on: November 03, 2010, 05:40:58 pm »
can you run under pipes on evo 2t blkes at a national
HONDA THE POWER OF DREAMS
Curly3
Re: evo class exhausts
« Reply #1 on: November 03, 2010, 05:46:06 pm »
I'm no rulebook expert but I can't see why not. They'd been fitting them to 2 Strokes for 2 decades previous.
Offline gdr
« Reply #2 on: November 03, 2010, 05:47:58 pm »
need the rule on it as we are starting to build the engine for next year
« Reply #3 on: November 03, 2010, 06:33:31 pm »
as evos have no date cut off or starting point i see why not.its for dirt track and down pipes are all the go for dirtrack bikes.pipes on tt500s do not follow the original they are all down pipes.there you go whats good for 1 is good for the other.
jim
Offline micks
« Reply #4 on: November 03, 2010, 07:14:19 pm »
you would have to be careful at the national level.someone may protest the oem rule if you beat them.
« Reply #5 on: November 03, 2010, 07:46:13 pm »
tt500s at the nats dont have oem your xl hondas dont have oem most racing 4 stroke bikes dont have oem.no one would be able to ride
if that was protested. all your 2 strokes with the coned pipes not oem.go to a dirt track meeting and see how many bikes have mods on there pipes.and this is at national level.i can show you pics of the 500cc australian evo champ bike 2010 mod/down pipe.
Curly3
« Reply #6 on: November 03, 2010, 07:54:16 pm »
I can't see it being a problem, short circuit was & is still based on modified bikes, if it was used in a previous era then it should be okay today.
« Reply #7 on: November 03, 2010, 08:05:53 pm »
look at all the pics of thr 2010 nats in griffith
1 in photos
1 in vintage track
« Reply #8 on: November 03, 2010, 08:35:25 pm »
i dont know what penny you are playing with but if i wanted to run my tt500 in evo it will pass with a speedway type pipe on it.they have been since 1976.
« Reply #9 on: November 03, 2010, 08:50:08 pm »
I can't see any reason why not, bar the dumb rule 18.3.0.4 'Exhaust must me modified but must generally follow original lines. If this rule was ever seriously enforced half of the bikes racing would be outed. The reason for its inclusion was to prevent modern "fatty" pipes in pre '75 but it's badly written. It should be either totally removed or modified to explain its meaning a lot better.
« Reply #10 on: November 03, 2010, 11:58:59 pm »
GO for it.  You would be in your rights to agrue the ''original line is that taken by an original aftermarket pipe of that period - which is easy to show in any picture of a bike from that era in a date mag.
Armed with that picture on your bike in that period you would have a solid case and would overrule the " generally "definition
Offline gdr
« Reply #11 on: November 05, 2010, 07:17:46 am »
thanks for your comments guys ,might just go with the down pipe and see what happens.
Offline micks
« Reply #12 on: November 05, 2010, 11:09:38 am »
gdr i think you didn`t really get a straight answer to your question yes or no.but i can tell you that the moms is printed a white paper but there is a lot of grey in there too.p.s don`t forget to fit a silencer 18.3.0.4 b)
