Author Topic: it 465 frame  (Read 1907 times)
Offline noisy toy
it 465 frame
« on: October 29, 2010, 05:12:40 pm »
Can any one tell me where i can source a good IT 465 frame? Just had mine blasted and its a bit rusty here and there, and rear loop is bent from a flip i think.(aren't they all? ;D )
Cheers, Shane
Offline mxmaniac
Re: it 465 frame
« Reply #1 on: November 14, 2010, 08:19:55 pm »
What year and are they the same as a 250?
Maico's, the only way to go.
Offline noisy toy
Re: it 465 frame
« Reply #2 on: November 14, 2010, 09:02:58 pm »
Mine is a 1981 5L5 it465. I am pretty sure they are the same as a 250. A YZ frame would probably do as i dont intend to register the bike, i think main differences between IT and YZ are the rear loop and some brackets and things for lights. Can anyone advise alternative frames?
Cheers Shane
Offline FourstrokeForever
  • AKA Mark H #35 VCM
Re: it 465 frame
« Reply #3 on: November 14, 2010, 09:27:33 pm »
Hey Shane, the 465 frame is exactly the same as the 250 apart from the numbers. You will also be able to use a "K" frame with minmal fiddling in the linkage area and airbox mount tabs. Try canberra motor cycle wreckers (they are a Yamaha dealer so may be listed under that, they are in Fyshwick) I picked up a 465YZ frame for a mate from there not too long ago
Offline shorelinemc
  • life sucks&then you die
Re: it 465 frame
« Reply #4 on: November 15, 2010, 03:57:20 pm »
Ihave an IT465 FRAME has had rear loop removed,has compliance plate,pick up only or you organise tpt ,6 pack of jim beam and coke is the price
Offline mxmaniac
Re: it 465 frame
« Reply #5 on: November 15, 2010, 09:05:36 pm »
i have an 81 250 frame in good shape
Offline noisy toy
Re: it 465 frame
« Reply #6 on: November 15, 2010, 10:24:49 pm »
Hi shoreline, PM sent. Cheers! ;D
