Author Topic: Marzocchi steering stem  (Read 2536 times)
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« on: October 25, 2010, 11:08:40 pm »
Would anyone know if the steering stem from the 38mm Montesa Marzocchi's is the same as the 35mm
VB Marzocchi's or if the KTM/CanAm steering stem is the same.  Someone in the past cross threaded the
top nut and I had to ruin the stem to get the top clamp off.
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: Marzocchi steering stem
« Reply #1 on: October 25, 2010, 11:15:20 pm »
VB 35mm stem is a different part number >:(
montynut
« Reply #2 on: October 26, 2010, 12:32:27 am »
Jared the steering stem in the 35mm VF250 front end is the same part number as the 38mm VE/VF/VG414 and also the H7's. Hope that helps. My VB360 has a 38mm Marzocchi front end in it (shortened 9" travel naturally).
3BT
« Reply #3 on: October 26, 2010, 09:18:29 am »
KTM stem is different. Fitted KTM 38mm to my 77 vb360 using 38mm zochi yokes from a 414.
Captain Bilko
« Reply #4 on: October 26, 2010, 09:36:02 am »
The triple clamps off that 360 of yours Greg was also KTM...... :-X
montynut
« Reply #5 on: October 26, 2010, 10:16:05 am »
38mm Marzocchi are legal on Pre78 as long as travel restriction is satisfied. As far as I know the KTM and Monty Marzocchi front ends are inter-changeable although there are several variations of Marzocchi yokes I think? Can-Ams and others (SWM) also have Marzocchi forks. They where some of the best forks generally available at the time.
« Last Edit: October 26, 2010, 05:30:54 pm by montynut »
Captain Bilko
« Reply #6 on: October 26, 2010, 10:25:58 am »
Someone hasn't been using their spell-check....... ::)
montynut
« Reply #7 on: October 26, 2010, 05:32:22 pm »
There actually on my 360 not off ;D ::)
