Marketplace
For Sale
cr250m 1976
Topic: cr250m 1976 (Read 3450 times)
elsie 125
A-Grade
cr250m 1976
October 13, 2010, 06:02:37 am »
hi guys, just got a 76 cr250m, to do up to race dirt track, would like 2 buy an exhaust pipe, muffler, cables, seat brackets, wonder if a down swept pipe would fit?? thanks for your help
jimg1au
Re: cr250m 1976
October 13, 2010, 06:41:42 am »
elsie
matcho mick has a nos barrell for this bike for salei think he wants $350.00
i have a vindro conversion as well mr250 motor pipe and spare barrell $500.00
thanks
jim
bigk
Kangaroo Flat Victoria
Re: cr250m 1976
October 13, 2010, 08:53:32 am »
I have a complete seat, some good engine parts, pretty mashed up tank and some other parts, no pipe though. I imagine a down pipe wouldn't be too hard to fit.
oldyzman
250 two stroke!
Re: cr250m 1976
October 13, 2010, 09:20:54 pm »
Hey Elsie,
I had one of those before, I was told that you can get an aftermarket down pipe prom the 74 model, you cut the pipe approx 6 inches from the flange spin it a bit and re weld it.As the 74 model comes out toward the other side compared to the 76 or just get a pipe made by GMC. I have a barrel on std bore for one of these available - jus needs a hone
Cheers Brett
Last Edit: October 13, 2010, 09:26:43 pm by oldyzman
jimg1au
Re: cr250m 1976
October 13, 2010, 09:22:54 pm »
brett&elsie
1975 1976 use the same pipe 1973 1974 are on the other side and down
jim
oldyzman
250 two stroke!
Re: cr250m 1976
October 13, 2010, 09:26:05 pm »
OK jim i will ammend, did the 75 hav an through frame pipe?
jimg1au
Re: cr250m 1976
October 13, 2010, 09:29:56 pm »
yes they did 73-74 same 75-76 same config
elsie 125
A-Grade
Re: cr250m 1976
Reply #7 on:
October 13, 2010, 11:39:26 pm »
thanks for your help guys, will send you all out a pm, have just taken top end off, now too attack bottom end, which needs new rod, gaskets, bearings and seals,
oldyzman
250 two stroke!
Re: cr250m 1976
Reply #8 on:
October 15, 2010, 04:07:18 pm »
Hey elsie r u in sydney?
jimg1au
Re: cr250m 1976
Reply #9 on:
October 15, 2010, 04:18:58 pm »
brett
he is in the act and a good dirt tracker as well on his 125s
elsie 125
A-Grade
Re: cr250m 1976
Reply #10 on:
October 15, 2010, 07:48:57 pm »
jim, thanks so much for your help, I brought a couple of those big end bearings from the link you sent me
Yes am in canberra oldyzman
oldyzman
250 two stroke!
Re: cr250m 1976
Reply #11 on:
October 15, 2010, 09:04:51 pm »
Hey Elsie,
if you were in sydney i was going to mention a couple of guys who have worked on cr's for many years...
Marketplace
For Sale
cr250m 1976
