Clubroom
Tech Talk
rm shockers
Topic: rm shockers (Read 2818 times)
steve7406
A-Grade
rm shockers
September 20, 2010, 05:15:10 pm »
Nearly finished a rebuild on a rm250t want to put piggyback shocks on it what lenth should they be.
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Re: rm shockers
September 20, 2010, 05:19:44 pm »
STD are around 16'' or 407mm
LWC82PE
Superstar
Re: rm shockers
September 20, 2010, 05:48:38 pm »
Check your measurement Stew, original is under 400mm about 396/397mm. 407mm would probably still be ok though.
Steve, if you want to get rid of your original 250T shocks let me know.
Last Edit: September 20, 2010, 05:51:44 pm by LWC82PE
suzuki27
Re: rm shockers
September 20, 2010, 06:09:31 pm »
Stick with standard or a few mm either side. 385mm to 395mm is best.This will change if you change the front end etc. The RMT's get a bit weird after 405mm - even at 405mm I reckon. Stay close to stock.
Clubroom
Tech Talk
rm shockers
