Author Topic: BUltaco gear box oil change volume???  (Read 8347 times)
Offline steve234
« on: September 06, 2010, 05:50:45 pm »
I have different sources advising different quantities for oil changes. One says 300ml the other 450ml.  What does everyone else use?
Steve
Bultaco M106 Astro
Wanted: Dirt track bikes / parts / info
Offline JAP 454
  • See Ya at the Skids
Re: BUltaco gear box oil change volume???
« Reply #1 on: September 06, 2010, 07:12:49 pm »
Bully book says , Gearbox 600ml initial fill , 450ml refill  90w
                       Primary case 300ml 30w
We've just fired up an Astro, so have done g/box and primary oils
Fossil
« Last Edit: September 06, 2010, 07:14:38 pm by jap454 »
« Reply #2 on: September 06, 2010, 07:13:51 pm »
Steve my manual says 300ml. Jerry
Mark Austin
« Reply #3 on: September 06, 2010, 10:39:40 pm »
Hi,
Primary case is 300ml, gearbox is 600ml.
I always use Castrol MTX which works well in the gearbox and no slipping clutch.
Mark
Offline BultacoMacca
« Reply #4 on: September 06, 2010, 11:17:35 pm »
Mk6 Bultaco Manual says:
Clutch dry 300ml, or refill 250ml of SAE 30
Gearbox dry 600ml, or refill 500ml of SAE90 (tilt bike over to drain out most oil)
Mk10 Bultaco Manual says:
Gearbox dry and also refill, 600ml of SAE140 (tilt bike over to drain out most oil)
« Reply #5 on: September 07, 2010, 08:37:24 am »
Ring Peter Schoene 0427507861
Offline steve234
« Reply #6 on: September 07, 2010, 10:06:57 am »
Thanks guys i'll stick with the 450ml as per bully book.
Bultaco M106 Astro
