Author Topic: Teflon coated pistons  (Read 7467 times)
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« on: August 21, 2010, 05:36:12 pm »
Need opinions pro's and con's on getting pistons teflon coated.
Have had zero experience with piston coatings.
        Thanks, Jared
Offline hitatreeonce
  • rather be an old fart than a young dickhead
Re: Teflon coated pistons
« Reply #1 on: August 21, 2010, 07:02:39 pm »
I wouldn't buy one , just sounds dodgie to me
Offline BAHNZY
« Reply #2 on: August 21, 2010, 07:53:58 pm »
A lot of pistons come with the the black teflon CERAMIC coating from new, Woosner is one that comes to mind. Where we have a bore that is marginal needing to go to the next oversize, we will teflon CERAMIC coat the piston and get another season out of it.
On any of the 500's that we built for the rigours of FINKE, it was almost mandatory.
It's no gimmick, we use it pretty much all the time.
« Last Edit: August 21, 2010, 09:46:52 pm by Bahnsy »
Rod (BAHNZY) Bahn
« Reply #3 on: August 21, 2010, 09:17:37 pm »
Had some slighty worn pistons ceramic coated as well. Brings them back to spec and gives another lease of life to hard to source pistons.
Offline dalesween
« Reply #4 on: August 21, 2010, 09:45:00 pm »
Back in about 84 i read an article in ADB where Geoff Eldridge applied some Kal Guard teflon coating to his KDX 200 pistons,raved about the stuff.
Dale.
Offline BAHNZY
« Reply #5 on: August 21, 2010, 09:45:08 pm »
Correction
Mick is correct, Ceramic Coating, not TEFLON coating.
Rod (BAHNZY) Bahn
Offline dalesween
« Reply #6 on: August 21, 2010, 09:58:36 pm »
I dont know about ceramic but i take that is baked on from the factory where the Kal Guard was a brush on additive.
Dale.
« Reply #7 on: August 21, 2010, 11:08:02 pm »
Coatings on pistons are usualy microns thick so I dunno how that is going to get it back to spec? On any engine tuned to anywhere near it's potential the coating wears off anyway...........................
Offline micks
« Reply #8 on: August 22, 2010, 12:02:10 am »
seen a piston with both cermic on the crown (white),teflon on skirt (black).pistion was from a air cooled road race bike. the owner said it worked but that was in a motor that would get pulled down after a meeting it was a hand granade.he had cermic coating in the exhaust port to keep heat out off the barrel.he had it done i think by hpc.
Offline BultacoMacca
« Reply #9 on: August 22, 2010, 12:36:36 am »
I've had my Bully piston done by HPC Coatings in Victoria for two race seasons now. Took it out today and its not bad, coating worn off of the skirt bottom, not the sides. As Lozza says, it only gets you maybe a thou' thickness extra.
« Reply #10 on: August 22, 2010, 09:24:26 am »
Coatings on piston crowns create detonation.
Offline BAHNZY
« Reply #11 on: August 22, 2010, 09:40:15 am »
Never seen coatings above the ring lands, always below the bottom ring land.
Rod (BAHNZY) Bahn
« Reply #12 on: August 22, 2010, 01:21:03 pm »
Yeah it used to be all the rage to get the top of the dome ceramic coated or something like that.
