Author Topic: PE400 Engine Number  (Read 4312 times)
rohan
PE400 Engine Number
« on: August 18, 2010, 05:45:47 pm »
I am having my poor old PE400 engine (see below) split and rebuilt at the moment and I need to confirm the engine is from a 1980 PE400T as the rest of the bike is.
The Engine number is 102872 and the frame number is 102974.
For the record are there any differences between the 1981 PE400 engine and the 80? I.e. will the crank and big end bearings be the same anyway?
Re: PE400 Engine Number
« Reply #1 on: August 18, 2010, 07:01:55 pm »
Pe 400 motors 1980 -81 are the same .....just remember to use C 3  bearings. Pay particular attention to worn clutch fingers as they tend to wear ( groove )
Have a good look at crank keyway primary drive ...... check for wear on gears .
Put a seadoo Hot rod  H 8117  in it.  ;)
                                       Cheers Stewart
« Reply #2 on: August 18, 2010, 07:07:15 pm »
I havent got the 82 parts book but if you ask Luke he can look in there and see what the first engine number is for the 82 model. As oldfart says, everything is compatiple between all 3 models.
Engine numbers did not match from the factory.
Offline frostype400
« Reply #3 on: August 18, 2010, 08:28:29 pm »
going on that you'd say it is the engine from the bike most of mine are 101 or 102 prefix and they are the same prefix as the frame you just go on that they can be 100's of digits out but if the prefix is the same it is likely to be the same motor it came from the factory with and it does have the bash plate right that means that it is 1980.
1971 tm400 and PE's
« Reply #4 on: August 18, 2010, 09:14:12 pm »
Yes, but i wanted to see if we could rule out it ( the motor) was a 82 model but i dont know what the 82 prefix is. Whats the prefix on your 82 model?
Offline frostype400
« Reply #5 on: August 18, 2010, 09:53:56 pm »
It isn't a 82 I have a 101 and 102 in the shed t and x models I will check but from memory 82 is 104
1971 tm400 and PE's
Offline frostype400
« Reply #6 on: August 18, 2010, 09:58:19 pm »
it isn't 82 double checked my 82 eng prefix is 105.
1971 tm400 and PE's
Offline frostype400
« Reply #7 on: August 18, 2010, 10:02:36 pm »
One thing you may be interested in is a gmc pe400 pipe I have the first of hopefully many Geoff will sell I will post photo's tommorow. ;)
1971 tm400 and PE's
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #8 on: August 19, 2010, 12:54:10 pm »
http://cid-407d7ef0965d3991.office.live.com/self.aspx/Pure%20Enduro/FAQ.txt
Offline frostype400
« Reply #9 on: August 19, 2010, 02:29:18 pm »
GMC muffler and pipe for pe400 very happy with it. :)
1971 tm400 and PE's
Offline frostype400
« Reply #10 on: August 19, 2010, 07:21:56 pm »
You would have to ask GMC but I think around $600 mark. :)
1971 tm400 and PE's
