Author Topic: loosening a nut on a DT175  (Read 11464 times)
Oldbiker
« on: August 14, 2010, 12:14:44 pm »
Help! Ive tried a rattle gun, breaker bar, wd40 on the main nut behind the clutch basket and it wont budge! I need to get it off so I can get to the main crank seals. Anybody??
Offline David Lahey
Re: loosening a nut on a DT175
« Reply #1 on: August 14, 2010, 02:17:36 pm »
Jam a thick folded rag into the pinch point of the primary gears to hold it still
previous pseudonym feetupfun
Oldbiker
« Reply #2 on: August 14, 2010, 04:53:20 pm »
tried that, even in sixth gear and rear brake jammed on...I'll find a longer breaker bar...
« Reply #3 on: August 14, 2010, 06:16:30 pm »
Some localized heat maybe. You better hope they havent used an incorrect grade of Loctite for that application if any.
Offline dalesween
« Reply #4 on: August 14, 2010, 06:30:06 pm »
Get as long a breaker bar as you will find,leverage works!,i had a countershaft sprocket on a ZX6R on so tight i had never struck the likes of it before, we tried heat WD40, everything but in the end a long piece of pipe on the ratchet handle was the one that won the day.
cheers Dale.
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #5 on: August 14, 2010, 06:34:20 pm »
Some old water pipe oh, 3 feet or more. Never has there been a more useful thing invented.
Slides over your socket bar and.. things get very easy  ;)
Archimedes knew what he was talking about... (I think he went to school with Lozza)
« Reply #6 on: August 14, 2010, 07:05:06 pm »
leverage works
Not always ;)
monaro308
« Reply #7 on: August 14, 2010, 08:30:16 pm »
It isnt a left hand thread by any chance?
Offline lukeb1961
    • PE175N
« Reply #8 on: August 14, 2010, 08:49:16 pm »
get a longer lever  ;D  (the Suzuki PE400 crank nut is l/h thread, btw)
« Reply #9 on: August 14, 2010, 09:05:29 pm »
If you read his initial post ? you will see it is the Nut on the clutch boss (main transmission shaft)(RH thread)That Oldbiker is troubled with.
If it is that tight or frozen(RH thread).  Hey, Old biker? ? I would choose not to needlessly load that much duress through the transmission with a rattle gun. “Leaverage” is the correct practice. Apply “a lock” to the opposite force at the exact point of resistance (IE; to the clutch boss, as Yamaha call it). Yamaha did make a special tool, YAMAHA PART#90890-01022.
I have manufactured a stronger tool. I have two similar engines to get out very soon. I could post the tool to you? But you would have to post it “straight back”. Where are you? ? PM me with your details.
Trust me you will be pleased at how easy that nut loosens, when you lock the clutch boss with this tool.
PS; The nut that holds the clutch boss to the transmission mainshaftt is a RH thread, so apply a LH undoooing force.
« Last Edit: August 14, 2010, 09:19:20 pm by MICK-DE »
Offline brent j
« Reply #10 on: August 14, 2010, 09:19:43 pm »
My TM125 was too tight to move when I stripped that. I ended up drilling a small hole in the nut and splitting it with a chisel. Wedging something in between the primary and clutch gears runs a risk of stretching or breaking the cases.
I agree with Mick De in holding the clutch hub so there is no load on anything else.
« Reply #11 on: August 14, 2010, 09:37:35 pm »
My advice would be to heat it up a little, not red hot though. Then let it cool and get some penetrating oil to soak into it. Leave it for a few days. You will be amazed that after leaving it for a few days it come undone easy. If it doesnt then it sounds like you have a Loctite Horror story in the making. The stuff can be good when the right grade is used in the right quanties for the right application but if its not then it can be your worst enemy and it can end in tears if your not careful, but even if you are carful it can still end in tears!. If the incorrect type has been used you will find you need to get the nut extremely hot, almost to red. Anyway i hope its not going to get that bad for you. if a 2.5meter breaker bar extension doesnt do it then your only option is the heat method or Brents method of getting the nut off. if its  the wrong sort of Loctite or  Loctite used in the wrong quantity then a breaker bar no matter how long, wont loosen it.
« Last Edit: August 14, 2010, 09:39:43 pm by LWC82PE »
Oldbiker
« Reply #12 on: August 15, 2010, 09:25:03 am »
thanks all. I'm trying to get the DT's crank seals replaced and this other nut is in the way! Yep Ive checked it's a right hand thread, many time I checked. No I havent stuck a screwdriver between the teeth of the cluth basket. Tempted tho....Locktite eh? I got no heat apart from a match, so a long pipe hopefully will do the trick.
« Reply #13 on: August 15, 2010, 11:35:49 am »
you can make your own clutch hub holder by welding a piece of flat steel to one of the steel plates to hold the hub.
obviously the flat steel needs to be narrow enough to exit though the hole between the clutch basket "Tangs"
Offline dalesween
« Reply #14 on: August 15, 2010, 12:15:53 pm »
Yeah, thinking back i have seen one of those, they are a good simple solution.
Dale.
