Author Topic: freaky was looking for one of these  (Read 7274 times)
Re: freaky was looking for one of these
« Reply #15 on: January 05, 2008, 06:21:31 pm »
hoony  im thinking of a start you   BASTARD  TUBE STRAIGHT THROUGHT THE AIR BOX   THROUGH THE AIR FILTER AND JUST CONECT THE CAN AND SPRAY  FROM THE OUT SIDE
for my bike that did not work, it must evaporate before it gets to the pot. directly into the pot Paul and your on a winner!
Offline Maicojames
« Reply #16 on: January 06, 2008, 03:31:56 am »
Take that forking starting fluid and use it up-sniff it or something-that crap will blow away all the oil in your cylinder. Your Maico needs a fatter pilot jet, or you need to 1. with a Bing-tickle, tickle-see fuel on the ground-lean bike on left side-put in 2nd gear-rock -or you can pull comp release and kick through slowly to prime engine.
2. with mikuni-same but no tickler-have to lean pover until it drools fuel on ground-put in 2nd gear-rock-or pull comp release and kick through slowly to prime engine.
3. Bring me over on plane-I will start all these bikes for ya. ;D ;D
Life is suddenly very Monaro
