Author Topic: CR 125 1975  (Read 8296 times)
Offline AJ
CR 125 1975
« on: August 02, 2010, 10:11:18 pm »
hi,
Just picked up an almost complete CR125M 1975. Has great compression but no spark. I would like to get it running before pulling down for restoration. I will clean electrical conacts first. Is the CDi the first suspect in electrical problems for this model.?
Fuel tanks has surface rust, I will try the rocks & water abrasive solution. Any better advice?
Pipe has dents & holes, I have seen DG's in the US that look good, (I presume jetting changes would be needed) opinions appreciated.
Items missing are side covers, fuel tank cap & Air box. Any hints on locating these?
Thanks AJ
090
Re: CR 125 1975
« Reply #1 on: August 02, 2010, 10:53:37 pm »
Hi AJ.
Air boxes are a hard find as they were generally thrown away being restrictive. I have a second hand fuel cap $20 plus post.
Side covers can be bought from Darren I would expect http://ozvmx.com/community/index.php?topic=13967.0
I am pretty sure a phosphoric acid is used to clean tanks . Maybe that rust converter would be the go as well.
With the electrical problem, make sure the easy things are checked first. Plug, cap, make sure the cap is screwed into the coil lead, make sure the CDI is earthed. After that I would be taking some readings from the stator windings. Always good if you can find someone else in your area with one to swap bits.
DG pipes are good but a little loud. I have one on my '74.
Where do you reside?
Re: CR 125 1975
« Reply #2 on: August 02, 2010, 10:54:57 pm »
dosent gmc make air boxes for 125s
Re: CR 125 1975
« Reply #3 on: August 03, 2010, 12:05:02 am »
didn't this model have points?  If so first place I would be looking.
090
Re: CR 125 1975
« Reply #4 on: August 03, 2010, 05:52:16 am »
I know GMC makes one for the '77 cr125. Not sure if it will fit the early frame.
They are all CDI unlike the 250.
Offline AJ
Re: CR 125 1975
« Reply #5 on: August 03, 2010, 09:00:15 am »
Maitland NSW
Re: CR 125 1975
« Reply #6 on: August 03, 2010, 09:38:16 am »
Now available, airbox to suit CR 125 elesinore 74 - 77
Weighs 0.84 Kg c/w modern 2 stage filter.  Offers more protection against the elements than the origianl 74 style "filter box" & weighs less that the original 77 airbox which weighed in at 1.6Kg
Polished alloy airbox c/w stainless bolt $ 242.00  (unpolished $187.00)
Filter cage $44.00
Pro-Comp 2 Unifilter $51.50
Unifilters available to suit most vintage bikes (also moderns)
Too many to list, PM or e-mail for details.
[email protected]
Offline AJ
Re: CR 125 1975
« Reply #7 on: August 03, 2010, 08:04:55 pm »
I forgot to mention the frame loop over the rear guard has been snapped off. I would appreciate it if someone could give the measurements to replace it.
thanks,
AJ
robert thomson
Re: CR 125 1975
« Reply #8 on: August 12, 2010, 06:18:38 pm »
Hi AJ, I'm over Paterson way cr125m 1974 if this helps.
Offline AJ
Re: CR 125 1975
« Reply #9 on: August 13, 2010, 09:23:18 pm »
Hi Rboert,
I have bought a tester, if I get no joy it would be great if you can swap parts from a runner to find the problem. I'm at Ashtonfield.
It would be great to see your bike anyway.
thanks AJ 0408437480.
robert thomson
Re: CR 125 1975
« Reply #10 on: August 13, 2010, 10:44:01 pm »
Hi AJ,  This weekend  at the  "Heavenvmx " meet at lakeside. Talk to you next week Rob.
Re: CR 125 1975
« Reply #11 on: August 14, 2010, 08:50:36 am »
Probably have a molested frame I could take the rear loop off if it helps.
Offline AJ
Re: CR 125 1975
« Reply #12 on: August 14, 2010, 07:56:54 pm »
K,
Even the measurements would be great. Thanks for the help.
Robert,
I thought Toronto was next week. I won't get there tomorrow. Please give me a ring next week.
AJ
Re: CR 125 1975
« Reply #13 on: September 15, 2010, 01:48:37 pm »
if they were good enough for him a CR will be good enough for you............ :D
http://www.youtube.com/watch?v=J8nJvgSlSiM
« Last Edit: September 15, 2010, 01:57:24 pm by Freakshow »
Offline AJ
Re: CR 125 1975
« Reply #14 on: October 19, 2010, 09:33:25 pm »
Freaky,
Yes, Steve McQueen loved his bikes more than his acting.
AJ
