Author Topic: YZ125G clutch basket  (Read 3691 times)
Offline Woody
  • Heaven #70
« on: July 27, 2010, 10:40:34 pm »
Guys
Still looking for a good YZ125G (3R3) clutch basket (62 teeth on drive)
looks like YZ100 J and k may be the same
and any other good 125G spares you may have to offload.
Woody
1983 CR250RD parts / parts bike also wanted any condition considered
WANTED
1988/89 125 - CR KX YZ
IT200 stuff
CR250RD parts
Re: YZ125G clutch basket
« Reply #1 on: July 28, 2010, 01:38:45 pm »
i might have one, i know there is a few bottom ends down  there either 3R1 0r 3R3 or 1R8 - i have at least one of those numbers im sure right  :D  ,  will check next time im down the farm,
Offline Woody
  • Heaven #70
« Reply #2 on: July 29, 2010, 08:45:47 pm »
that'd be great freaky. from what I can tell this clutch basket only ran across those three particular models.
WANTED
IT200 stuff
CR250RD parts
Offline ELC hunter
« Reply #3 on: August 01, 2010, 07:24:37 pm »
Does any one know if it 175 g is the same have one of those .
Offline Woody
  • Heaven #70
« Reply #4 on: August 01, 2010, 11:02:59 pm »
thanks but from what I can see they have a different part no. and no. of teeth
WANTED
IT200 stuff
CR250RD parts
« Reply #5 on: August 02, 2010, 12:26:41 am »
OK the one i have is in a 1R8, but has stamped 1m1 on the clutch cover plate itself, with  cut outs on the hub finger and angled mesh mesh ring.
if i had a camera i would have taken a photo, also stood on my fone and it filled with water, amoung other disarters on the weeknd so i have nothing to show you :'(
Offline Woody
  • Heaven #70
« Reply #6 on: August 02, 2010, 01:29:10 pm »
thanks for looking Freaky, sounds like you had an interesting weekend.
the basket for the 125G is stamped 1W1 (like alot of others) byt has 62 teeth. I think the boss might be stamped 1G8. I can try and post a pic of one later on.
WANTED
IT200 stuff
CR250RD parts
« Reply #7 on: August 02, 2010, 06:45:27 pm »
So what are you asking me ? to count the teeth on the primary ring ?
Offline Woody
  • Heaven #70
« Reply #8 on: August 02, 2010, 09:59:54 pm »
that's a lot of teeth to count.  :D if it's not stamped 1W1 then it's probably not the right one. here's a pic
WANTED
IT200 stuff
CR250RD parts
« Reply #9 on: August 03, 2010, 01:25:22 pm »
Where excatly is it stamped 1w1 ?
