Author Topic: Montesa Cappra Project (1984 H7 in disguise)  (Read 8569 times)
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: Montesa Cappra Project (1984 H7 in disguise)
« Reply #15 on: November 27, 2010, 07:14:39 am »
Isn't the brake lever on the rear supposed to be on the top side?
DT_Mania
« Reply #16 on: November 27, 2010, 04:35:44 pm »
Yes you are right. I have been shown the errors in my ways. I will correct soonest. Now with the actuating lever turned around, do the connecting rod run underneath the shock, between the 2 plates of the shock mount?
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #17 on: November 27, 2010, 06:35:57 pm »
If the cable dosn't rub on the bottom of the shock too much,
I would think it would be ok.  Normally it rides outside the shock
and wears on the swingarm :(
Captain Bilko
« Reply #18 on: November 27, 2010, 06:41:15 pm »
Some of mine run under the shock, some outside of it. Just depends on how much of a bend the actuating arm has I guess.
That bike is looking grouse DT. Matched that fork paint perfectly. That isn't some of Luis's (Solomontesa) paint is it?
I run a fair amount of slack in my chains. That swingarm pivot point/countershaft sprocket relationship eats up a lot of slack when the suspension's working. The slack adjuster actually touches the swingarm on the bikes that I ride to reduce the chances of what Jared descibes happening to the c/shaft bearing.
I'd be getting a rear sprocket with the holes in them. Monties look agricultural enough without a solid rear sprocket.... :P
Great job mate..... ;)
« Last Edit: November 27, 2010, 06:48:24 pm by 66M »
Offline hitatreeonce
  • rather be an old fart than a young dickhead
« Reply #19 on: November 27, 2010, 07:15:20 pm »
I dont understand why it has a front disc? I like the earlier motessa's but I'm confused?
Captain Bilko
« Reply #20 on: November 27, 2010, 07:25:49 pm »
The H7 360's had a disc front brake (well some anyhow).
« Reply #21 on: November 27, 2010, 07:58:39 pm »
OK never seen one before
