Author Topic: 79 pe250  (Read 2309 times)
motodevo
79 pe250
« on: July 15, 2010, 09:28:36 pm »
hi guys, got a 79 pe250 that runs ok but will not go into any gear above 4th gear, i am assuming its a 5 speed (i only know IT's) but when you try to shift up its like your already in top gear. What i want to know is what is the likely suspect? Any suggestions of what to look for when i split her. Also does anyone know of anywhere on the net i can download a manual? Thanks in advance
steve
Offline frostype400
Re: 79 pe250
« Reply #1 on: July 15, 2010, 09:46:34 pm »
Gday Steve should be a 5 speed check out Lukes skydrive for info http://cid-407d7ef0965d3991.skydrive.live.com/browse.aspx/Pure%20Enduro
you won't really know till you split it which you will have to to fix what ever is wrong. :)
1971 tm400 and PE's
Re: 79 pe250
« Reply #2 on: July 15, 2010, 09:47:29 pm »
http://groups.yahoo.com/group/PEmotorcycles
Probably missing detent plunger.
