Marque Remarks
Yamaha
Reproduction IT/YZ 465/490 Connecting Rods
Topic: Reproduction IT/YZ 465/490 Connecting Rods (Read 4260 times)
ranchak
July 10, 2010, 04:41:16 am »
Hi Guys, I am looking into having the Connecting rod reproduced for the IT/YZ 465/490s. These will be kits: connecting rod, crank bearing, crank pin, thrust washers and rod bearing. They will be made in Japan. These will not be available for sale until December or January 2011. Looking at a retail price of $139.95. Any thoughts, ideas or interest?
Thanks, Ron Anchak
www.anchakandsons.com
Re: Reproduction IT/YZ 465/490 Connecting Rods
July 10, 2010, 06:18:15 am »
Bookmarked
You're a great resource Ron - and very reasonable prices.
ranchak
July 10, 2010, 07:53:47 am »
Thanks for the kind words, Ron
retrowrex
Novice
July 10, 2010, 08:04:58 am »
I have an IT490 which should have a rod not so far into the future. Are ProX not availble or as cheap and also made in Japan? I assume thats in US dollars and with post may or not end up cheaper or then the same as a ProX.
Retro
Apparently you can only ride one bike at a time, and hence you should only have one bike.
LWC82PE
Superstar
Reply #4 on:
July 10, 2010, 09:28:35 am »
When i tried to get a rod kit for a YZ490 a few months ago, there was no aftermarket one available. ProX didnt make them. Only option was OEM off ebay.
caps 999
Reply #5 on:
July 10, 2010, 10:46:00 am »
do you recon you could lookint making cr480 rod kits ranchack theres no where to get these at the moment
MUGEN power
retrowrex
Novice
Reply #6 on:
July 10, 2010, 01:11:41 pm »
There you go. I will likely be lining up for one down the track then.
Retro.
Freakshow
Superstar
Adelaide, SA - looking for a "YZA" tank
Reply #7 on:
July 10, 2010, 08:43:43 pm »
dONT THEY USE funny 22m top end bearings og something where are you getting them from ? bit like the astupid 24mm bottome big ends on the DT1 no prick has them
74 Yamaha flattracker's
70 Jawa 2 valve speedway's
For sale - PRE 75 Yamaha MX stuff, frame, motors and parts also some YAM DT1,2,A and Suzi TS bikes and stuff
Davey Crocket
Reply #8 on:
July 10, 2010, 09:52:13 pm »
Are you on the turps again Freaky?....english is getting a bit swaheally
Freakshow
Superstar
Reply #9 on:
July 11, 2010, 12:30:18 am »
soz, on work laptop and it has that stupid pad window, wrist touches it and it moves the cursor, then there my fat fingers, and of course my fat head. anyhow im sure you can figure out what im talking about
Davey Crocket
Reply #10 on:
July 12, 2010, 06:12:47 pm »
Yea I can figure it out after a carton of fourXXXX
Marque Remarks
Yamaha
