Author Topic: rm125 b or c  (Read 7784 times)
Offline noisy toy
Re: rm125 b or c
« Reply #15 on: July 14, 2010, 09:51:10 am »
Hey thanks for the pics. My frame has the same tube bracket below the coil mount to bolt on to the fuel tank brackets. It also has the clip things to hold  the rubber tank mount, where i think the b has 2 of these rubber mounts which are riveted on. I thought i might have had the optional alloy swing arm, but my rear brake stay is attached to the frame, not the swing arm. I also have rubber mounted handlebars, i think the b is solid? So it seems i have a c with a b rear wheel and early serial number for some reason.
Thanks for that.
monaro308
Re: rm125 b or c
« Reply #16 on: July 14, 2010, 02:09:06 pm »
Put up some pics of your rear end on the brake side and sprocket side and we can suss it out in 2 secs.
If you need more pics,i took a few of the rebuild as i went along.
cheers...Mario
