Author Topic: XL500 Gearing for MX & RM Swing Arm mods  (Read 6890 times)
Offline PB
« on: June 30, 2010, 06:39:25 pm »
Hoping for some advise?
XL500 project is taking shape. CR front end is fitted. I was hoping someone could help me with the following:
1. I have a RM400 swingarm to fit. Do they fit without modifications? And do you run the XL Wheel or RM?
2. What gearing should I run for MX?
Thanks to anyone who can help
PB
DT_Mania
Re: XL500 Gearing for MX & RM Swing Arm mods
« Reply #1 on: June 30, 2010, 06:46:30 pm »
Sorry but I have no helpful input. Just sounds like a great project. I wanted to run a tricked DR400 motor in a RM370 frame once but never got around to starting with the project. Mmmmmmm........maybe I must have a re-look at it!
Pics?
« Reply #2 on: July 02, 2010, 09:50:02 am »
Can someone please help Bundi (poofboy is his real name), he won't listen to me. I know exactly how his wife feels.
« Reply #3 on: July 02, 2010, 10:02:12 am »
Too much information K, just too much info  :o ::) ;D
Offline SUZUKI311
« Reply #4 on: July 02, 2010, 03:21:53 pm »
How dare you bastardise a Suzuki swingarm by putting into a ....Honda...
Offline PB
« Reply #5 on: July 04, 2010, 09:05:49 pm »
CAN ANYONE HELP ME?
I have read on a previous post about putting a RM swing arm in a XL500 frame? Before I attempt to install it I was hoping someone who has done it could offer some advise other than calling me poof boy? (BigK) Or bring up the wife, who buy the way doesn't have a clue what I am upto?
PB
Offline crossedup2
  • Never enough shed time.....
« Reply #6 on: July 04, 2010, 10:01:09 pm »
Bundi
Save yourself all the hassel with the swingarm conversion. You'd be better off getting two old XL arms and make one longer one by cutting, welding and painting. Make the new arm the same length as the RM if this mod works as well as you believe it does. It might even allow you to run an 18" honda rear.
As for gearing, I enduro'd an XL500R in '82. I just put the biggest rear sprocket I could find because the knobbies use to make even that gearing pretty tall. (I think it was bigger than 48 teeth on 17" wheel)
Good Luck
Peter B
« Reply #7 on: July 04, 2010, 10:21:21 pm »
some inspiration
Offline PB
« Reply #8 on: July 05, 2010, 08:59:42 pm »
Thanks for the comments and inspiration. Thats exactly the long term project. I already have the front end in with twin leading shoe front brake. I will probably leave the backend until after Viper on 8/8. I hopefully with Big k help will try a CR480 tank and seat. I will post some photos down the track.
Thanks again
PB
« Reply #9 on: July 06, 2010, 09:52:42 am »
Use your spell check. You are after some "advice" or looking for someone to "advise" you. Get it right!
ride red
« Reply #10 on: July 29, 2010, 09:36:31 pm »
hey. rm swingarm fits with minimal fuss . i run it with the xl wheel only because thats what i had . 395 - 400 length shocks . spacers between swingarm and frame on each side . small though . shocks angle in very small amount because frame mounts dont quite line up with swingarm . all said and done , works well . mines on a xl 250 , frames the same .
Offline PB
« Reply #11 on: July 29, 2010, 09:45:00 pm »
Thanks Ride Red
I have the swing arm and now you have given me the confidence to do it. I am happy to hear you used the xl wheel.
Big K and I have got it looking good. New front end, xr seat, painted tank, and new plastics. Looks good for  what it is.
After ravo 8/8 I will change the swing arm.
Thanks for the help.
PB
